Go Back   CNCzone.com-The Largest Machinist Community on the net! > WoodWorking Machines > Commercial CNC Wood Routers > Excitech routers
Excitech routers Discuss excitech routers here.
Old 12-23-2008, 08:44 PM
daviddansky is on a distinguished road
C and Y axis diffferent
I have a 1325c, and after crashing y into neg. stops gently, the c axis and y are not the same i try adjusting the homing sensor for the y axis, but cannot get this to work. Any suggestions
Thanks all
Old 01-07-2009, 08:47 AM
Hi everyone i emailed tech support at excitech and got a clear answer in 24 hrs. Can't beat that. I want to post if anyone esle has the problem.
When Y and C axis value are not the same, for example, when you let machine go home, the X: 0.000 Y: 0.000 Z:0.000 C:-2.638
Here you may adjust the C axis to be C:0.000 the same as Y: 0.000.
The following steps show you how to adjust:
1. at desktop press F6(Parameter)==>F5(Goto param)==>input "886", press F1(OK)==>input "0", enter, input password "520", enter.
2. let machine go home again, it will show you X:0.000 Y:0.000 Z:0.000 C:-3.858(for example)
3. again, press F6(Parameter)==>F5(Goto param)==>input "886", press F1(OK)==>input "-3858" (attention: with no "."), enter, input password "520", enter.
4.let machine go home, you'll see all the numbers are "0.000"
Old 01-07-2009, 12:47 PM
mhkwd is on a distinguished road
David,
Thanks for sharing this with us. I tried it and it works.
Mitch
New Machine Build- post for 2 axis ez trak versus 3 axis ez vision tooolman G-Code Programing 0 11-28-2008 04:33 PM
Compare Catia and MCX2 for multi axis lathe/4 axis mill bob1112 General CAM Discussion 0 10-10-2008 08:15 PM
How can I coupling a stepper motor axis directly to other axis? meknik2001 Stepper Motors and Drives 4 05-08-2008 02:54 PM
One axis (z-axis?) computer controlled testing device TsThorsell Stepper Motors and Drives 3 02-07-2008 01:38 PM
New Design - Hybrid 3-Axis Router/4-axis Foam Hot Wire Cutter the__extreme CNC Wood Router Project Log 3 02-26-2007 03:58 PM
