Go Back   CNCzone.com-The Largest Machinist Community on the net! > WoodWorking Machines > Commercial CNC Wood Routers > Excitech routers
Excitech routers Discuss excitech routers here.
  #13   Ban this user!
Old 06-08-2009, 06:38 AM
rocket67 is on a distinguished road
Originally Posted by jubee View Post
ROCKET,Give the guy a break,
I have read both of his posts on Yako drives and now the usb key thing,
and Iam sorry but I cant find anything that reseambles bashing the Excitech
Machines.
We all have established you are one happy customer with the Excitech machine,
But would you believe there are some problems that crop up,
With Excitech Machines and all the others for what its worth.
In which I thought this forum was about!
If people have legitamate problems,then why souldnt they be address.
jubee, yes - you are probably right and i am just overly suspicious of some posters. If i am wrong - apologies to those concerned.
This is the sort of thing i referred to -
So far Ive had 4 of the Chinese ones from exitech and 2 other random makes, the exitech one are way too flimsey, but the lexar 1g are very robust and have last well so far.
And this -My worry is how long the USB slot in the DSP is going to last ? mines already feeling a bit loose
Certainly not the case in our experience
I have no wish to pick a bun fight - but am i the only one to be suspicious of these sort of comments?
Graham - if you are on the level - i withdraw my comments.
Rocket.
  #14   Ban this user!
Old 06-08-2009, 10:34 AM
GraHutch is on a distinguished road
Rocket
Firstly I’m, truly disappointed with your comments, and was going to ignore your post, but have decided to reply so as to expose you to the rest of this forum for what you are…which I’m am sure the open minded and intelligent users of this site can figure out.
I am a genuine user of the machines you appear to be obsessively passionate about, and do not profess to be an expert, hence I rely on people out there for help, of which, I have had some genuine helpful hints and guidance. thank you to them, I am not an Electro mechanical expert, I am a patternmaker so hence my clumsy and sometimes desperate approach to my electrical problems, our business relys on these machines to be up and running at all times, so anything that can speed up that process when a problem occurs is a godsend.
My posts are sincere and factual as per my experience with this piece of equipment, and for the record I have always sung the praises of Exitech, never wittingly commenting in the negative, as I have said in the past my experience has been a positive one.
It was my intention by contributing to this forum to pass on any experiences and solutions that help to solve problems others are experiencing.
Lastly, I will not be bullied off this forum by your offensive messages, at least have the decency to make them public, keep your profanities to yourself.
Before I publish your comment.. I’ll give you the chance to apologise and publish it yourself….
Graham.
  #15   Ban this user!
Old 06-08-2009, 01:09 PM
cabnet636 is on a distinguished road
that sure looks like a shop on the level to me!!
good looking setup graham
jim
James McGrew camaster x3, aspire software
www.mcgrewwoodwork.com
  #16   Ban this user!
Old 06-08-2009, 04:55 PM
Well now i am just jealous!
Originally Posted by GraHutch View Post
Rocket
Graham.
Graham - refer to my post above.
I repeat - Graham if you are on the level i withdraw my remarks.
As far as offensive comments are concerned... You can only be referring to my Edited post in which i told you to f... off. Which i edited quite quickly as it was not called for.
But please ... Go right ahead and expose me for what you say i am. Been there before with carvinmarvin. But before you spin any rubbish - be aware of this - A long time ago i gave my password to a moderator on this forum. This was to give access to my private messages to the moderator - just in case anybody tried to pull any stunts.
Over to you.
Rocket.
  #17   Ban this user!
Old 01-31-2011, 09:24 AM
purnama_cam is on a distinguished road
Guys,
Need help with my excitech machine (SHM1325 using HSD Spindle AT/MT 1073-140). Yesterday while working, my spindle suddenly sounding unusual loud noise, and the spinning went slow and broke the tool.
After opening up the upper case, the lacquer bearing appeared dirty. So I used automotive engine degreaser to dissolve the dirt. But the wrecking sound still there, so I need to open the spindle motor to check whether the lacquer bearing is still in good condition or need to be replaced.
Can someone tell me how to dismantle the spindle to change/clean both the top and bottom lacquer bearing?
Thank you
need help a.s.a.p (as jobs ordered are overdue)
Thank you
Purnama_cam
Ubuntu/EMC2 Bootable Flash Drive 123CNC LinuxCNC (formerly EMC2) 14 02-12-2009 11:13 PM
Newbie- demo / flash drive rsm169 NCPlot G-Code editor / backplotter 2 05-23-2008 05:46 AM
Flash drive USB to parallel or serial port input lowtech4 Computers and Networking 0 03-03-2008 03:45 PM
USB Flash Drive HelicopterJohn Haas Mills 30 11-23-2007 06:40 PM
EZ TRak DX w/flash drive will not home ataylor_316 Bridgeport and Hardinge Mills 7 07-01-2007 06:01 PM
