Results 1 to 8 of 8
Thread: The sh-cnc Excitech 1530 B
    Dec 2006
    australia
    Smile The sh-cnc Excitech 1530 B
    Here are some photos of our ripper Excitech cnc Router.
    There are lots of photos to post. I am starting with photos of the machine and spindle, and will add more in other posts.
    Rocket.
    Attached Thumbnails Attached Thumbnails The sh-cnc Excitech 1530 B-dsc00723.jpg   The sh-cnc Excitech 1530 B-dsc00783.jpg   The sh-cnc Excitech 1530 B-dsc00774.jpg   The sh-cnc Excitech 1530 B-dsc00779.jpg
    The sh-cnc Excitech 1530 B-dsc00756.jpg   The sh-cnc Excitech 1530 B-dsc00745.jpg   The sh-cnc Excitech 1530 B-dsc00684.jpg   The sh-cnc Excitech 1530 B-dsc00691.jpg
    The sh-cnc Excitech 1530 B-dsc00679_edited-1.jpg   The sh-cnc Excitech 1530 B-dsc00686.jpg
    Dec 2006
    australia
    The Electrics
    More photos of the electrical system and components. If anyone has any particular photos they would like to see close up - just let me know.
    Rocket.
    Attached Thumbnails Attached Thumbnails The sh-cnc Excitech 1530 B-dsc00820.jpg   The sh-cnc Excitech 1530 B-dsc00683.jpg   The sh-cnc Excitech 1530 B-dsc00682.jpg   The sh-cnc Excitech 1530 B-dsc00688.jpg
    The sh-cnc Excitech 1530 B-dsc00730.jpg   The sh-cnc Excitech 1530 B-excitech191.jpg   The sh-cnc Excitech 1530 B-excitech190.jpg   The sh-cnc Excitech 1530 B-excitech183.jpg
    The sh-cnc Excitech 1530 B-excitech185.jpg   The sh-cnc Excitech 1530 B-excitech187.jpg   The sh-cnc Excitech 1530 B-excitech209.jpg   The sh-cnc Excitech 1530 B-excitech180.jpg
    Dec 2006
    australia
    Smile More photos
    Note becker vacuum pump.
    We manufacture and install built in robes with sliding doors. The Excitech`s job is to router fancy patterns into the doors.
    Attached Thumbnails Attached Thumbnails The sh-cnc Excitech 1530 B-dsc00780.jpg   The sh-cnc Excitech 1530 B-dsc00757.jpg   The sh-cnc Excitech 1530 B-dsc00760.jpg   The sh-cnc Excitech 1530 B-rimg0006_edited.jpg
    The sh-cnc Excitech 1530 B-dsc00743.jpg   The sh-cnc Excitech 1530 B-dsc00727.jpg   The sh-cnc Excitech 1530 B-dsc00674.jpg   The sh-cnc Excitech 1530 B-excitech174.jpg
    Jan 2006
    New Zealand
    Quote Originally Posted by rocket67 View Post
    Speaking of which, do you find it holds things down well enough? I have read on the net that a 5' x 10' router needs around 20KW to hold down really well. That works out to about NZD$20 an hour to run. I will just use clamps at the same time than fork out that much $$$ for power. We have just purchased a second hand Becker VTLF250 for a VERY good price
    Shannon.
    Dec 2006
    australia
    Becker pump - No worries mate!
    Pump has not given us any trouble. Holds our panels very well, but all of our panels are large - as in the smallest sheet would be 1200 x 2400.
    The only time we had a panel move was quite funny. The rep who was trying to sell us a $100,000 Router ( before we bought the Excitech) came in to see if we were still interested in his machine. I proudly took him down to have a look at the Excitech. Ramon was routering a panel at the time and the bloody panel moved! The rep went off with a smirk on his face.
    I was going internally beserk! Ramon said it had not happened before and has not happened since. May have been someone from upstairs having a bit of a lark!
    Our accounts man has not mentioned anything about the power bill jumping up in the router factory. I will ask him.
    I hear that the New Zealand Dollar is not worth much, so your $20 is probably $5 in OZ.
    Jan 2006
    New Zealand
    Or maybe less than $5 but its still $20 less that I wont get paid though. the smaller pumps should be fine with correct 'vacuum management'
    You would have to have a LOT of panels move before you get to $100,000 for that other router.
    Shannon.
    Registered BC-CNC's Avatar
    Jan 2008
    Shannon,
    Just wanted to chime in and mention that we bought the Chinese version of the Becker VTLF250, 10HP pump with our CNC.
    While we were hooking it up and bumping it to check for correct rotation I couldn't resist running it with just a 5' x 10' sheet of MDF on the table, not machined or sealed in anyway. I threw a scrap of melemine about 8" x 20" on the table and it sucked it down and held it in-place no problem. The router did come with a large vaccum tank that must be increasing it's performance, but I am not up to speed on what role it plays in vacuum systems.
    Regardless, I can't imagine how the pump wouln't be sufficient with a properly sealed spoilboard and using the various strategies for small parts holding.
    Spencer.
    Nov 2006
    The reason most manufacturers recommend 15 to 25 HP vacuum pumps is leakage. You can use a small high vacuum 1/3 HP pump to hold parts, we do it all the time. BUT if you get any air leak between the part and the table...the part is gone. The MDF sacrificial board doesn't flow much air through its pores, so you need a high volume pump to maintain adequate vacuum at the part. There are a few things you can do to help.
    Use a dedicated fixture with rubber gasket and suction holes. Good for repeat jobs, but not good if you are constantly changing jobs.
    If your blank doesn't cover the whole table, cover the unused areas with something to block off the vacuum loss. Anything flat and thin is OK. Formica, thin plastic or even poly sheet ( it's hard to keep poly sheet where you want it).Also think about sealing the edges of the MDF with masking tape or paint.
    Take a skim cut on both surfaces of the MDF. The surface is usually less porus than the middle due to the way they make it.
    Use LDF because it has larger spaces between the particles of wood.
    BC-CNC
    The tank lets a smaller pump build up a reserve and helps keep the vacuum at a higher value if you get a momentary leak. Problem with a tank is if you do have a constant leak the vacuum will start to drop and now the pump has to try to evacuate the tank AND keep the part on the table.
    HTH
    PW
    1. Excitech SHM 1530A
      By GraHutch in forum Commercial CNC Wood Routers
      Last Post: 03-18-2012, 10:39 AM
    2. Excitech Cnc Router Purchase
      By rocket67 in forum Excitech routers
      Last Post: 12-07-2011, 04:59 PM
    3. RemainCNC NZ Excitech 1530 router.
      By Big S in forum Excitech routers
      Last Post: 08-20-2010, 06:12 PM
    4. New Excitech SHM1312 machine
      By Kent_Norway in forum Commercial CNC Wood Routers
      Last Post: 09-30-2008, 03:24 AM
    5. Excitech controller quest
      By Matty Zee in forum Commercial CNC Wood Routers
      Last Post: 08-07-2008, 05:26 AM
