Go Back   CNCzone.com-The Largest Machinist Community on the net! > WoodWorking Machines > Commercial CNC Wood Routers > Excitech routers
Excitech routers Discuss excitech routers here.
  #109   Ban this user!
Old 11-20-2007, 02:40 PM
KustomKoncepts is on a distinguished road
well if they are name brands thats fine. I read somwhere that one guys machine had no labels or markings on the motors or spindel. they where all genaric smooth silver finish parts, with some chinese label.
I see in jimmy's pics that the label says HSD ITALY motor. so I figure if last bet a guy buys a replacement from HSD right.
I had a spray in bedliner system and a blower motor went out and they wanted $800 for a replacement. When the second motor went out I went to a local Gemco max/air and found the sand thing bolt patern even for $250. so if that is how this machine is I'm ok with that.
Am I correct, I could buy almost any spindel or motors or drive system and basically replace the parts? am I right in thinking that I mean are parts interchangable?
  #110   Ban this user!
Old 11-20-2007, 02:59 PM
Esmae is on a distinguished road
You're absolutely right. Steppers, rails and screws are all standard sizes. As for the spindle it's easy to make your own mount if you get another one.
  #111   Ban this user!
Old 11-20-2007, 03:08 PM
I have friends who have Mills that could cut out a mount for me if needed.
  #112   Ban this user!
Old 11-20-2007, 03:14 PM
Originally Posted by Jimmy007 View Post
Esmae I'm sure i have the 'ZHBDSPhandheldhost' program somewhere also, never loaded it. What does it do?
First Gcodes I ran were generated in Type3 and saved straight to the USB stick to run from the hand controller. Like you I generated different progs with file names as a tool change solution.
Not a garage or basement- stairs lead to a clean room upstairs where I do electronics assembly but its never clean cos I leave the door open so I can hear what the machine is up to ;-p
What lube are you using?
I found machine gun oil is the only thing i have found to date that sticks to the guides.
Yep the ZHB....... program gives you a toolpath preview on the computer and also sends the file to the controller. I haven't really looked into it much cause it's a bit buggy. But it does what i need.
By the way i have a computer connected to the controller and that computer is networked and pulls files from our server. I haven't even tried the usb stick option before. I understand that most people will just run the controller straight from the usb stick (no computer attached)
I use Slideway oil, I get it from a machining shop down the road. They get it in 200lt drums i get some every 4-5 months
  #113   Ban this user!
Old 11-20-2007, 03:21 PM
You'll have a router. You can cut one yourself
  #114   Ban this user!
Old 11-20-2007, 04:20 PM
Originally Posted by cabnet636 View Post
carvin oh where art thou carvin ??
man i really want to see some photos
cabnet
Maybe he don't have a camera!!!!!
  #115   Ban this user!
Old 11-20-2007, 04:25 PM
cabnet636 is on a distinguished road
carvin oh carvin
he said he had photos
cabnet
  #116   Ban this user!
Old 11-20-2007, 04:32 PM
I don't think he likes us anymore
  #117   Ban this user!
Old 11-20-2007, 04:43 PM
parts
kustom the parts absolutly interchange nema 34 motors whether stepper or servo refer to 3.4 inches of center between mounting holes with 1/2 inch shafts the parts are available at mcmaster carr. grainger i got a lot more
and gotta go to an appointment ($$$) i have a quote from josh and will be here more tonihgt cabnet
Old 11-20-2007, 04:54 PM
ger21's Avatar
HSD USA is in Florida, and can rebuild your spindle if/when it need repair. We've recently had two 10 year old spindles rebuilt by them.
  #119   Ban this user!
Old 11-20-2007, 10:13 PM
way down under in land of
australia home of crocidile dundee
http://www.multicam.com.au/
  #120   Ban this user!
Old 11-20-2007, 10:19 PM
carvinmarvin is on a distinguished road
shcnc - jinhan - excitech
I notice there is one here for sale on the auction.. you might be able to get it at a decent price?
Used VF2 possible purchase, just a few ?'s JMFabrications Haas Mills 21 04-01-2011 12:34 PM
Best purchase? cnc@52 Milltronics 17 10-09-2007 02:19 PM
Looking to purchase a new Vf1 DRD Haas Mills 12 09-13-2007 05:06 PM
want to purchase a CNC from anyone corbyvhall Benchtop Machines 1 03-24-2005 07:08 PM
purchase or building a home cnc router. s_bedow DIY-CNC Router Table Machines 9 03-19-2005 12:22 AM
