Go Back   CNCzone.com-The Largest Machinist Community on the net! > WoodWorking Machines > Commercial CNC Wood Routers > Excitech routers
Excitech routers Discuss excitech routers here.
Old 08-31-2010, 10:24 AM
hernee is on a distinguished road
shg 1212 y axis problem.
Hi, I'm new.
I bought this machine one year ago(used).
the machine a week ago started having problems with the y-axis.
For example when I'm making a cut 3mm mdf and is moving along the y axis suddenly get stuck and you hear the motor straining without result.
I want to know if someone happened something similar.
(Sorry for writing, not my native language)
Hernan
Old 09-01-2010, 02:31 PM
rocabig's Avatar
rocabig is on a distinguished road
I dont have the 1212 i have the 0609 but had the same problem
it ended up being the pretensioning nut on the bearing for the
ball screw shaft had tightened itself a bit too much
just back it off a wisker and check if it helps.
Richard
Old 09-07-2010, 01:59 PM
Hi richard thanks for answering the question.
We discovered after struggling a while with the machine that was not the y-axis
The problem is in the cable connecting the CNC to udisk (to false contacts).
Greetings and thanks again.
Tags
shg 1212, y axis probelm
KL-1212 is on the way! rosco Automation Technology Products 3 02-11-2010 01:25 PM
SHG 1212 SWC Excitech routers 2 11-04-2009 02:07 AM
Possible used SGH 1212 purchase laurentian Excitech routers 0 10-27-2009 06:21 PM
1212 EXITECH ALIVE SIGNMAD Excitech routers 0 10-20-2008 05:04 PM
Excitech 1212 Setup HELP!!! SEALvet2 Excitech routers 23 08-24-2008 11:00 PM
