- Servo motor info.
Servo motor info.
question Is excitech e2 atc series cnc router with delta servo motor 400 watts fixed with reducer.
One other option is 750 watts belt driven system.
Which is good.
or 400 watts with reducer is good enough to heavy duty work like solid wood work run Aggregates etc.
servo motor also had load while cutting work.pieces?
Reply is appreciated.
Thank.u
- Servo motor info.
- You may not post replies
- You may not edit your posts
Forum Rules
