- Z Axis stops before it touches the material...
Router (Excitech 2030) was cutting fine yesterday, but late afternoon it started doing the following. Example : We have a 32mm mdf plate and want to cut from top of plate. The settings on the software is correct and we got top of plate. The router goes to the starting point, the Z axis moves down and then the head stops about 15mm above the material. On the dsp, the z goes down as per normal to a certain point (15-17mm above material) and then start counting down in microns, but the head does not move. We have formatted the dsp already, checked all the settings on the software, tried bottom of plate, tried other artwork, even tried just a simple rectangle, but it keeps on doing this. Any one else experienced this?
- You may not post replies
- You may not edit your posts
Forum Rules
