Need help
Results 1 to 14 of 14
Thread: Need help
    Registered bananafish's Avatar
    Aug 2008
    Default Need help
    I have Chinese Excitech router with DSP.
    I have a problem with DSP.
    It was working OK last time I used.
    I tried to load the file using new USB memory stick today.
    When I selected U-drive to read the file, I could see the name of the program.
    After selecting the file I wanted to run I hit the OK button.
    Normally spindle start to spin here.
    But I couldn't go any further from there.
    Then I tried to run the factory installed "inner memory" (sample program)but the name of the file (was Chinese fonts) went funny and cannot read or run the program.
    At last I have tried using original USB stick to load the program.
    After selected the file from U-drive then I hit "OK" then "Inner memory in not enough pls delete some files" came up on the DSP display.
    I never installed any program direct into DSP inner memory and there were only few sample files installed by factory.
    Can anyone tell me whats the problem is ? and how to fix it.
    Should I delete inner memories ?
    Please HELP
    Aug 2008
    Default more trouble
    I have deleted "inner file" through
    >>>advance pro set up
    >>>file maintenance
    >>>delete
    Once I selected inner files and hit OK button, DSP displayed "deleted"
    But It still show the broken file names.
    Anyway, After deleted the inner files the machine could read the program and started working.
    But Z axis didn't go down to where it should be, and Y axis went too far so I had to hit the stop button.(I'm not sure about X axis )
    I think spindle rev and XYZ axis runs faster than how they should be.
    Can anyone explain why it's happened and how to fix it.
    Registered Inuk's Avatar
    Feb 2010
    I'm not an expert in this but have you tried Inner Format (Menu>System Setup>Inner Format). I've done it a couple of times to resolve issues and it seems to work. You'll need to reset all setting such as Pulse Equivalents, Machine Size, Home Speed, Gcode read etc. so record them all before hand. It will wipe any existing cut files from the DSP.
    Hope this helps.
    Aug 2008
    Quote Originally Posted by Inuk View Post
    Hope this helps.
    Thanks Inuk
    Does Inner format just reset settings and cutting files ?
    It doesn't format firmware ?
    And can it be done with dsp pendant(handset) ? no need to connect to PC ?
    Feb 2010
    I'm relatively new to CNC and so I'm not sure if there are different versions of the excitech DSP or whether the functions/terms are the same given the menus are so cryptic. The term 'Inner Format' send shivers up my spine but it works for me. Any time the machine has misbehaved I've done the Inner Format and it seems to straighten it out, but like I say it wipes the machine settings and any inner (cutting) files on the DSP. I've never been able to get a USB to work with mine.
    I've just done the procedure again to refresh my memory and it does require the resetting of any data in MACHINE SETUP and AUTO PRO SETUP.
    Does Inner format just reset settings and cutting files ? - on mine yes
    It doesn't format firmware ? - on mine no
    And can it be done with dsp pendant(handset) ? - Yes (Menu>System Setup>Inner Format)
    no need to connect to PC ? - Correct
    Version View for my DSP is:
    Initial version RZNC-D5416/3/L7, 1.2, Hgq68 20817
    Normal Version RZNC-D5416/3/L7, 1.2, zhb177 20817
    Not sure exactly what these mean but if they are Model/Series and the same on yours I guess you'd be OK. How old is your machine ?
    Aug 2008
    Inuk
    Thank you for your help.
    I bought my machine SHG1212 just a year ago.
    My DSP version is
    Initial Version
    RZNC-D5416/3/L30
    1.2(ZHB59)
    34152
    Normal Version
    RZNC-D5416/3/L30
    1.2(ZHB1560)
    34152
    On my DSP, "Excitech" logo comes up when it's switched on.
  7. #7
    Feb 2010
    Tried to send this off thread but your mail is full.
    Did an inner format work for you ?
    I have the same machine though I bought it used. I beleive it's about 6 years old. I'm interested to know what you use yours for ? What CAM program do you use ? I've never seen a logo on my DSP.
    Btw are you able to control the spindle spd from code ? I've not been able to do this, I have to use the VFD.
    Cheers
  8. #8
    Feb 2010
    Hi Bananafish, found this Manual over in another forum. Might Help.
    Attached Thumbnails Attached Thumbnails Need help-mo-con501_full_manual-pdf
  9. #9
    Aug 2008
    Thanks Inuk, Iris
    I'll do little more research and give it a go tomorrow.
  10. #10
    Aug 2008
    I've done "inner format" today.
    After formatting DSP, all the parameter went back to default automatically.
    Only setting I have to change manually is "Pulse equiv"
    They were XYZ : 400 400 400 after formatting.
    That travels Y axis twice more distance so I needed to change them to 400 200 400.
    I had a test cut and it was almost successful.
    I noticed spindle spins a lot faster even if I used same program I used before.
    Is there any setting I can change the spindle rev via DSP?
    I didn't touch VFD at all.
  11. #11
    Aug 2008
    Hi,Folks
    I need help resetting the DSP to be able to control the spindle.
    Is there anyone who can help me out over the phone?
    I'm in Sydney.
    Please PM me if anyone can help (preferably someone in the same timezone).
  12. #12
    Aug 2008
    Problem solved !
    I had a reply from Excitech.(It was very quick indeed !)
    Machine is now working perfectly.(I think )
    The settings I needed to change were
    INPUT SPINDLE ST 2e NUMBER: to INPUT SPINDLE ST 7e NUMBER:
    Then 7 lines of setting came up. ( I only had 2 lines before )
    The setting I have is
    0 down down down down
    1 up up down down
    2 up down up down
    3 up up up down
    4 up down down up
    5 up up down up
    6 up down up up
    Now spindle speed can be controlled via DSP and program(v-carvpro).
    >>> Inuk
    I thins your DSP is same as mine.
    Try those setting above.
  13. #13
    Aug 2008
    Default Spindle speed setting for SHG1212/DSP/VFD-M
    More information came through from Excitech.
    Please note that those settings are for
    Excitech SHG 1212 late 2009 model
    DSP + Delta VFD-M inverter
    I have set the parameter according to the info I received yesterday.
    And it seems working OK.
    Attached Files Attached Files
  14. #14
    Registered shapebuster's Avatar
    Mar 2014
    Lisboa
    Default Re: Need help
    Hello Everyone!
    I have a Chinese Suda sd1325 or vg1325 cnc.
    My dsp shows this for bothe INNER VERSION and NORMAL VERSION:
    RZNC-D5416/3/ L7
    1.2 (HGQ692)
    20288
    Do you know any reason why my controller is not receiving/reading the usb files?
    I go through the controller menu, i pick the "u disk file", apparently it tries to read (usb pen light flashes) but its not showing the files of the usb. I thought it might be from a bad usb pen, i tried with a new one, and nothing...
    I also tried to connect the controller to my PC, but i'm stalled by a "not recognized usb..." message. I am running windows 8, and not even picking the controler files manually it recognizes the controller, and therefore im not able to run nothing...
    Its strange because the controller is working well, and controls the machine.
    Any clue/suggestion?
    Best regards
Need help
Need help
