Page 2 of 3 FirstFirst 123 LastLast
Results 13 to 24 of 34
Thread: Excello 604 cnc mill info.
  1. #13
    Registered Karl_T's Avatar
    Mar 2004
    Dassel,MN,USA
    Quote Originally Posted by Al_The_Man View Post
    Link P.M'd.
    Here is the spindle mod.
    The 'Gear' Tooth is for a tach.
    Al, I assume you only did this cause something was broken??
    I use mine with both the varispeed and the VFD. Set the speed in the right ballpark with the varispeed, then use the VFD attached to a pot on the control when running.
    Karl
  2. #14
    Dec 2003
    Well for one I did not like the unknown rpm with the vari-speed, also it was noisy.
    I have a Acroloop motion card running Acromill with one of the analogue outputs to control it, so I can issue a M3 & S value for the spindle.
    I have an input that indicates when it is in low gear.
    Mar 2005
    Question
    Thanks for the replys guys,I have built a small cnc mill with stepper motors and am using Mach3 with it and I really like it so I think Im going to go with it.
    So would I be better off going with the rutex drives or the gecko drives in your opinions or something else.I really like the look of the gecko drives they look really easy to wire up. But I also know they only go to 80volts and 20 amps and I need 85 volts,28 amps so I dont think they will work. Any opinions on this would be great.
    Thanks Mike
  4. #16
    Dec 2003
    If going with Mach and the same motors you could look at Larking Viper drives, I have not used them however, but it appears there are a few here that have.
  • #17
    Mar 2005
    Smile
    The 604 was used by a few OEM's for CNC conversion, so it depends on what controller is on it?
    Many had SEM DC brushed motors with old Westamp drives.
    I have the original manual in PDF, this would be before conversion.
    PM sent.
  • #18
    Mar 2005
    Here is a picture of my servo motor.
    It looks like it says .7 amps could this be right?
    Thanks Mike
  • #19
    Dec 2003
    What is the dimensions of the motor?
    What is reduction/gearing involved?
  • #20
    Mar 2005
    Hi AL,
    The dimensions on the motor are 4" diameter x 11" long including the tach. and about 6.5" for just the motor to the back of the brushes.
    The gearing looks to be a 2 to 1 ratio.
  • #21
    Dec 2003
    I think the decimal is an accidental DOT!
    More like 7A at least.
  • #22
    Mar 2005
    Hey AL,
    I hate to keep asking you questions but it seems like your the only other member with an Excello 604 cnc mill. I think Im going to start another thread just on my conversion when I get a few more things done. I have started to gut the old control and Im wondering if you used your old power supply.
    I was wondering if I keep everything in the main power panel or not,heres a picture of the inside of the main panel.
    Attached Thumbnails Attached Thumbnails Excello 604 cnc mill info.-6094dd451cfcbaac1305760207.jpg
  • #23
    Mar 2005
    I think your right.
    Thanks mike
  • #24
    Dec 2003
    See this one in post #3, its sister.
    http://www.cnczone.com/forums/vertic...knee_mill.html
    Yes I used the same power supply and kept what I needed in the panel.
    Mine posts #8 to #12.
    http://www.cnczone.com/forums/camsof...tallation.html
  • Page 2 of 3 FirstFirst 123 LastLast
    1. Excello Mill
      By Miller Man in forum Linear and Rotary Motion
      Last Post: 02-03-2012, 10:33 PM
    2. Help! Any info for excello 604/605 cnc mill
      By Sparky_NY in forum Knee Vertical Mills
      Last Post: 02-17-2011, 10:51 AM
    3. Need Help!- excello xlo 602 mill help!
      By xlojon in forum Knee Vertical Mills
      Last Post: 02-17-2011, 10:13 AM
    4. Excello CNC Mill with Kwik Switch Spindle ATC Options
      By bochek in forum Bridgeport and Hardinge Mills
      Last Post: 12-15-2009, 05:44 PM
    5. Upgrading an EXCELLO CNC mill
      By MikeAber in forum Servo Motors and Drives
      Last Post: 04-13-2008, 02:57 PM
