- Europe CNC Simulator Pro
CNC Simulator Pro
Hi,I am new on this forum and an absolute newbie in CNC programing.Currently I am practicing in CNC simulator Pro.Is there a way to check the dimensions of processed workpiece to see if your code was good?I am using free version of CNC simulator.
Re: CNC Simulator Pro
Hi....I was going to walk this path with a simulator too as I'm new to CNC, but you can't really beat having the mill of your choice operating with the G code of your own.
.I use a pointed wooden dowel in the spindle and a soft Polystyrene foam block marked with the points I want to test the G code on..........this is a safety feature and you can touch down on the foam with the wood dowel and see if the code produces the tool path you planned on........only in a 2D format, but as it's a learning curve for manual G code programming, the end result is simple and not a disaster if you make a wrong code move.
A lot depends on if you intend to write your own code which is what I'm doing.
A more complex program produced with CAM is a different matter as there are Z moves that a wooden stick won't be of any use for.
Ian.
- You may not post replies
- You may not edit your posts
Forum Rules
