Need help with ID part serial number on CNC producton machine
Results 1 to 3 of 3
Thread: Need help with ID part serial number on CNC producton machine
    Jan 2016
    Question Need help with ID part serial number on CNC producton machine
    Hello everyone,
    I am James and I am new to the forum.
    Does anyone know if it is possible that ID or mark the serial number of the finished part on the production CNC machine?
    Thanks,
    James
    Feb 2013
    United Kingdom
    Default Re: Need help with ID part serial number on CNC producton machine
    Quote Originally Posted by JamesZhao View Post
    James,
    A little more explanation would help as the sentence above does not mean anything.
    Are you trying to add a serial number to a part that has been made?
    Are you trying to find a serial number on a CNC machine?
    The answer to either will depend on the type of CNC machine you are using.
    - Nick
    I quite like targeted ads if they're not intensely annoying so I'll enable ads when your advertisers stop using annoying sounds, annoying slideshows and annoying animations
    Member john-100's Avatar
    Mar 2007
    uk
    Hi James
    is this the kind of marking you want to do :-
    see 2:20 machine using live tool to engrave the part
    if you need to mark parts with a part number it will be quicker to roll the number onto the part
    the down side you need to have a roller made for each job
    John
