Hey
who can roadrunner.tap, from mach3
Drop here.
with mine something went wrong
greeting
It's in C:/Mach3/GCode.
If you're missing the face that's because you don't have a license and the 500 line limit for the demo stops the full job cutting,
- Nick
I quite like targeted ads if they're not intensely annoying so I'll enable ads when your advertisers stop using annoying sounds, annoying slideshows and annoying animations
The file is actually embedded in each version of the software. If you see the entire roadrunner in Mach when you load the Gcode the file is fine. If it does not cut the entire roadrunner in demo mode because now Mach is time limited and you can't get the entire thing cut before demo mode runs out. This is now true in both versions of Mach3 as I recall.
Russ
