- Europe cutting scroll saw patterns on a cnc machine
hi every one ....I am going to try and cut scroll saw projects on my hobby cnc machine ....does anyone do this if so what cutter to use ..any help will be appreciated from you ...thanks john...
Re: cutting scroll saw patterns on a cnc machine
yes I do it all the time.
I use cutters from End-mills, drill bit, router bits, CNC toolholders, PCB dry film - FrezyCNC.eu
Their fish tail cutters the 1.59mm dai and smaller are what you need, I use the 1.59mm cutter to cut through 13mm ply, 1mm doc per pass 15000 rpm and feed of 3000mm per min.
Works well, have cut over 2000 small parts and no breakage on the cutter.
They have small dia cutters and Im sure they would work well.
Postage from Poland is cheap and I've had very good service from them.
Cheers
Andrew
- You may not post replies
- You may not edit your posts
Forum Rules
