did u ever figure out how to do it
Hi All,
Can anyone help me on how can i wire the attached laser on my cnc machine?
I do not want to use PWM on breakout board. I will create a new profile on Mach3 "Laser".
My thought is to wire the laser on a-axis at breakout board and under ports&pin input on Mach3, on z axis set the
pin of a-axis "DIR", in this way every time in gcode z goes down will turn on the laser and vice versa, correct?
This way i have to manipulate the gcode every time, correct?
Is there any other better way?
Do you have any reference of G,M,S gode that i will need?
Thanks a lot
