Go Back   CNCzone.com-The Largest Machinist Community on the net! > Events, Product Announcements and More > CNCzone Club House > Europe Club House
Europe Club House Europe Club House discussion forum.
Old 10-05-2009, 05:37 AM
wds wds is offline
wds is on a distinguished road
wee problem with our busellato jet
we have a fault showing on screen warning( flashing) - STOP :CHECK COLLET and/or Tool Signals on ELECTRIC SPINDLE 2
we have overcame the problem but are wondering does anyone know the cause!! a wee note this has occured after a weekend of no use on machine and sudden drop in temperature! after we went through the heating spindle process the fault appeared on screen!
thanks in advance!!
Old 10-05-2009, 10:02 AM
drollnor is on a distinguished road
thanks in advance!!
Did you get any more detailed error message ??
Anyway,,,, start with a good cleaning of all the sensors
next, check the connectors ON the router engine, I have had some problems with them loosening on the cnc machine I am running ( Jet 3006 ), but this machine have been i production since 02.....
Actually had to solider back a signal wire last week ( didn't get any look signal so the machine wouldn't run )
Arne Kjetil
Old 10-09-2009, 07:45 AM
wds wds is offline
Arne Kjetil
hi arne, no more detailed error message but will make sure we give good clean and check!!!! thanks again!
Old 10-15-2009, 07:26 AM
wds wds is offline
thanks in advance!!
the problem still seems to be there, every couple of days we have to close all current programmes and start again!! have tried all the cleaning etc!! can anyone help???? cheers!
Old 01-17-2012, 03:15 PM
andycmi is on a distinguished road
We had the same problem, we looked at the device signals and found that there was a conflict; 'Collet closed with tool' and 'Collet closed without tool' were both lit at the same time. We brought in a tech, who told us this was due to worn sensors inside the head and then 'fixed' the problem by instaling a toggle switch which would jump out the conflicting signals.
Andy
Need Help!- AlphaCAM Post Processor - Weeke and Busellato bwilkerson Post Processor Files 18 01-25-2012 10:30 AM
Busellato vs Weeke MARKC53 Commercial CNC Wood Routers 11 11-22-2011 05:33 PM
Need Help!- Busellato Jet 2000 Rust CNC Machining Centers 2 10-20-2011 02:52 PM
Busellato Problems mcmxl22 Commercial CNC Wood Routers 4 09-03-2009 09:20 AM
V Carve pro and Busellato JET 3006 Vectric 23 03-07-2008 04:10 AM
