Go Back   CNCzone.com-The Largest Machinist Community on the net! > Events, Product Announcements and More > CNCzone Club House > Europe Club House
Europe Club House Europe Club House discussion forum.
Old 04-30-2009, 04:43 AM
amisdaniel is on a distinguished road
Need Help !
Hello everybody !
Can anyone help me with this problem?:-Transfer program PLC NUM 1060W.
Type CNC BIMA 800 with 22 axles.Thanks !
Old 04-30-2009, 09:23 AM
Aiman Ebraheem is on a distinguished road
What type of program do you need to transfer?
Is it a part program? Is it a PLC program?......
Old 05-02-2009, 06:51 AM
Hi Aiman Ebraheem !
The machine lost the memory because akku is dead .I change the akku but i do not know exactly what file must be transfer in PLC and in CNC. I used to transfer X_GEMA.EXE.I have experience with a similar machine BIMA810. For this machine we have all necessary steps for transferring program.But are different.We found in hard disk and a floppy disk but you do not know exactly what should be transferred and in what order.Anyway, i transferred some inspiration from Bima 810 for the first time and were turned out until digitale.But not until we know exactly what should be transferred not think we will succeed.
Thank You !
Old 05-03-2009, 11:47 AM
Dear Admis
"The machine lost the memory because akku is dead" .
What is akku??
Any way, I have NUMTool. This software can be used to transfer all types of files to NUM CNCs
PLC files *.xla
Parameter file *.xpa
These are the main files which must be transferred on backup processes
Old 05-04-2009, 04:10 AM
Dear Aiman Ebraheem !
The Akku battery is Ni-Cd 2.4 V mounted on the CPU board.I think i do not transfer all parameters machine *.XPA. Only these groups of files*.xla and *.xpa should be transferred ? I ask you because for BIMA 810 i transferred *.xcx and *.xus *.xla and *.xpa.Today i delete all and i transferred only these groups of files*.xla and *.xpa.Do you have the same machine or something ? Do you know how many files contain each group?
I keep in touch. Thank you !!
Best regards !!
Old 05-04-2009, 09:49 AM
Dear Amisdaniel
No, These are the main files not all files. You may also need to transfer *.xpi which are stored in the protected areas of memory.
What is BIMA 810
Yes, I have CNC milling machine with NUM POWER 1040 control system
It depends upon the OEM (Original Equipment Manufacturer) not NUM
Till me Amisdaniel
What is your machine builder or OEM
How do you transfer files into CNC (by which software)?
What type of files do you have? How is it obtained?
What is your MMI? Is it Industrial computer?
Best regards
Old 05-06-2009, 08:54 AM
The manufacturer is IMA-NORTE. BIMA 810 is similar with BIMA 800.
I used to transfer X_GEMA.EXE.With this program I transferred files from BIMA 810.This machine(BIMA 800) never worked in our factory until now.Is a second hand machine.And I also CncDisk version 2.0.0.0 .I made a special cable for this software.
I have not found any file with extension *. XPA .Is that bad? At this moment do not make reference point.File with the errors and the tools not found.That I want to know what order and what files must be transferred.But your machine is different.Thank you because you tried to help me.I do not know if the hard disk there all software for CNC.Someone from Germany ( where it was bought) wiped windovs 3.11 but not wiped out and the way in autoexec.bat.And X_GEMA.EXE runs under Windows 3.11.I installed windows 3.11 again.Now X_GEMA.EXE running.
This is why we made comparison with BIMA 810.We started with successful another machine BIMA 600.But this I know all the steps.And is the simplest.
Best regards !!
Old 05-06-2009, 09:27 AM
Dear Amisdaniel
Can you send the backup files which you use?
You can send it to ebraheemaiman@yahoo.com
Regards
Old 03-31-2011, 02:39 PM
RAVENEXTREME's Avatar
RAVENEXTREME is on a distinguished road
Hello. :( need NUMBackup tool ...
Hi ppl. Hi Aiman. I read that you have the UM Backup tool. Is that correct ? I already have posted various replys with my problem and even one post but until now there is no answer I'm having touble ( specialy finances ) with my NUM and the assistance takes my founds away with restoring the info and replacement of the battery. I dont know if you could help me on this question but untill now i dont have any solution
Hope someone could help
tanks in advance
