| Europe Club House Europe Club House discussion forum. |
| Hi All I am considering buying some ballscrews to put on my little X1 milling machine and are getting a bit confused as to the type of ball nuts on offer. The only difference I have seen apart from increased cost is the amount of backlash in the ball nut. The 3 types I have seen are:- 1.0 as is about 0.04mm backlash 2.0 Preloaded with increased size balls( unknown backlash) 3.0 Preloaded with a spacer (again unknown backlash but costley as it uses 2 ball screws) So considering that I am replacing a fairly grotty chinese screw thread will the first ball screw (also the cheapest option) be OK in the long run or just hang the expense and go to preload. Peter |
| Hi Peter, I have just very recently ordered some ballscrews and nuts from here http://www.homeshopcnc.com/page3.html . I am using two nuts/axis to make an adjustable zero backlash setup. Hope it will be of some help to you, John |
| Preloaded ballscrews shouldn't have any backlash. Personally, using a machine without backlash is well worth the cost involved. I'd look at the two options and try to determine what the other features involved were, as I'm not familiar with a functional difference in preload methods aside from ease of adjustment. There should be more features that cause the price difference, not just preload mechanism. |
| CRC Type | binzer | GibbsCAM | 2 | 07-06-2007 12:48 PM |
| What type of Computer do you Use? | diarmaid | Hand Tooling | 20 | 03-09-2007 12:55 AM |
| What type of CNC do this work ??? | villas | DIY-CNC Router Table Machines | 31 | 08-19-2006 08:17 AM |
| Big Ball Screw & Ball Nut mistake. | Jack F | General Metal Working Machines | 12 | 04-28-2006 11:53 PM |
| what type of CNC do I need? | Goldhunter_2 | Mechanical Calculations/Engineering Design | 6 | 06-24-2005 11:57 PM |
