Results 1 to 2 of 2
Thread: HELP! - HOW WOULD YOU PROG??
    Dec 2011
    UK
    A little help please, how to program in G code for a simple task.
    16mm thick bright mild steel plate held in a vice. 25mm drilled pilot holes at required places. How do I interpolate a 30.00mm bore using a 12mm End Mill with cutter comp applied so I can tweek the tool radius to allow for wear & keep size?
    I am struggling with the approach in & out particularly.
    I have put the cutter at the hole center (no comp) & moved it straight out to 15mm rad applying G41? & using G03 X Y I J sending it all the way round back to start position of circle. Then trying to cancel comp G40? moving back to circle center giving me an error which I cannot remember. So my attempt is obviously totally wrong. Can anyone give me a correct example? PLEASE!?!?
    Regards.
    May 2010
    G0 Z2.5
    G1. Z-20. F1984.07
    G41. D1 Y-6. F3968.14
    G3. X9. Y0 I0 J6. F1984.07
    I-9. J0 F3968.14
    X3. Y6. I-6. J0 F1984.07
    G40. Y5.4
    G0 Z25.
    Give this a go.
  1. MFG engineer/prog needed in NC to 77k
    By BILL WRIGHT CCR in forum Employment Opportunity
    Last Post: 01-10-2012, 08:31 PM
  2. fanuc/yasnac out prog
    By anddy26 in forum Rhinocam
    Last Post: 09-10-2011, 08:05 AM
  3. Newbie- Best Cam prog?
    By greven2010 in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 06-13-2010, 04:11 PM
  4. Need Help!- Prog ex Mazatrol M2
    By sve0019 in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 05-30-2010, 01:48 AM
  5. Sample prog?
    By Edster in forum Okuma
    Last Post: 09-25-2008, 02:52 PM
