Go Back   CNCzone.com-The Largest Machinist Community on the net! > Events, Product Announcements and More > CNCzone Club House > Europe Club House
Europe Club House Europe Club House discussion forum.
Old 12-28-2011, 08:18 PM
yakari is on a distinguished road
making fins
Hi
I make surf fins out of wood.
I have a hard time imagining how a cnc machine can make the profile on both side of the fin. how do i do that?
any experience with something similar?
Old 12-29-2011, 05:45 AM
CaptainVee is on a distinguished road
I make small rudders through a casting process and am now working on milling the moulds where I used to cast those from hand made master moulds.
You can also mill them from two sides, leaving some material uncut to keep the thing connected to the stock, then turn over using guide pins for positioning, then mill the other side.
If you mill two in a mirror image side by side you only need one file and use that twice.
I am using pycam to create the g-code from .stl file.
Sven
http://www.puresven.com/?q=building-cnc-router
Tags
cnc, routing, surf
Model Engine Cooling Fins jamesjsmj RFQ (Request for Quote). 0 05-24-2011 09:28 PM
Need Help!- cooling fins still juniormachinist Mastercam 8 05-19-2011 04:53 PM
Need Help!- radius on the end of the fins juniormachinist Mastercam 2 05-06-2011 05:39 PM
raduis on the end of fins juniormachinist Mastercam 9 04-29-2011 10:17 PM
Newbie- How to cooling fins? pmsmichelle Mastercam 10 08-17-2009 05:36 PM
