| Europe Club House Europe Club House discussion forum. |
Hi I would need someones help to CNC the following two parts. ImageShack Album - 7 images (will send high resolution pictures if you PM me your email) They should be made of a very stiff and hard black plastic. 0,01mm tolerance. I would pay about 100-200€ for both parts. (depending on end result) ![]() Please PM me if you are interested in the job. Best Regards Alex |
| That part is quite complicated. If you plan to have a part made just by sharing pictures you will be lucky to get +/- 1 mm... I would suggest you have the part scanned in so that you have a 3D model of the part, that can then get you somewhere close to 0.1 mm accuracy. Accuracy should only be defined tight where it is needed, though. I have no idea what your part is or how it works, but I suspect most of the dimensions are there to "take up space" and are not critical at all. A few may need to be as close as 0.1, or even the 0.01 you started with, but there would be only a few of them that are needed that tight.
__________________ CAD, CAM, Scanning, Modelling, Machining and more. http://www.mcpii.com/3dservices.html |
| Alex, I have looked at the models and drawings. Have some questions about what you need and out of what type of materials. I should be able to cut the parts for you, will need to do a work up of a model to make sure we are on the same page and then figure out machine time for you. Drop me an e-mail or message and we will see what can be done with them and go from there. Michael |
