| Europe Club House Europe Club House discussion forum. |
Hi everyone. I am an American searching for special hand files that I used many years ago when I worked for Michelin Tire Corporation. There doesn't seem to be an American equivalent. These files were flat for about three quarters of their length, and then tapered in both width and thickness, giving them a slight bump that could be used for filing high spots on a flat. We just called them French files (this was almost twenty years ago, so I may have forgotten the technical name for them). Any pointers to suppliers would be helpful. Thanks, Thomas |
| Hi Thomas There is a specialist file called a 'bulls foot' normally circular with the handle attached at right angles to the circular cutting pad. These files are common in clock making as well as tool making and are used to remove material in the middle of the work. However they are normally small and available only in the finer grades. Just a thought but wh not grind away the teeth on either side of the active area to create a cutting platform with which to correct the job? Regards - Pat |
| I went to Hardwick's Hardware here in Seattle, which has one of just about every file made, including milling files and riffler files. None of the files are the same. I may have to contact some old colleagues at Michelin to find out what these files are. |
| Need Help!- European Standard ????? | mashteuiash | General Material Machining Solutions | 4 | 03-25-2009 10:56 AM |
| European EMC meeting brainstorm! | svenakela | LinuxCNC (formerly EMC2) | 2 | 09-03-2008 03:45 PM |
| Is there a UK or European Classifieds ? | Andrew_standen | Europe Club House | 1 | 07-24-2008 04:51 PM |
| European forums | single phase | Hypermill | 5 | 11-13-2006 01:29 PM |
| coverting from Right-hand to left-hand coordinate system | eltonr | General CAM Discussion | 6 | 10-14-2004 08:40 PM |
