Page 51 of 394 FirstFirst ... 414849505152535461101151 ... LastLast
Results 601 to 612 of 4724
Thread: Epoxy-Granite machine bases (was Polymer concrete frame?)
  1. #601
    Sep 2006
    Martinw,
    Just curiousity. Yes, my orientation was about 3 hours of gore (lower case). Referred to as stinky vacs (old). Typically the specs (negative pressure) were expressed in MB. Basically meaningless to me. If I remember correctly atmospheric is 17 psi so that sounds pretty good.
    Have to pick up one of those books.
    Mike
  2. #602
    Mar 2003
    Shelby Twp, MI....USA
    14.7psi
  3. #603
    Sep 2006
    Ok Ger21,
    You got me, I'm not from this planet ; )
  4. #604
    Dec 2005
    UK
    Quote Originally Posted by ger21 View Post
    14.7psi
    Dear jsage,
    Gerry is spot on.
    To relate to other units, here are a few more conversions
    One atmosphere=14.7psi=1 bar=1000mB
    Best wishes
    Martin
  • #605
    Sep 2006
    I know he is. I just have 17 stuck in my brain. Though I'd swear I'd seen 17 before. Thus the joke. Either time has effected my memory of it, likely. Or perhaps I was thinking of maximal clamping pressure, unlikely. Second time I have made that error. 6 years from now I'll probably say 17 again ; )
  • #606
    Jan 2007
    Texas!
    Well, Cosmetically its not beautiful but it is definitely functional. I found that the best thing for sealing up gaps between the frame and base was a mix of 5 minute epoxy and sand. Once I had the gaps all sealed up I started mixing up batches of the main course. OK starting weight of base 100 lb. Steel frame 15 lb. Completed weight 180 lb. So 65 lb of epoxy, sand, rock mix. The following weights are approximate- Sand 17 lb, rock 38 lb and epoxy 10lb. So that gives us about 55 lb of filler and 10 lb of epoxy. When I was mixing it I was going by volume case I didnt have a small scale to use. I found that 1 part epoxy, 1 part sand and 3 parts rock was user friendly and had good wet out of the filler. One bucket batch I tried with 4 parts rock and it was too dry, not enough epoxy. There were a lot of gaps between the rocks and it would not have bonded together well like that so I added some epoxy to get it to the consistency of the other batches. With about 1/4 or 5/16 of an inch to go on the fill I ran out of rock and mixed up some sand and epoxy to try and finish up. After I had poured it in and smoothed it out that batch had a lot of tiny air bubbles in it floating on top. I didnt have that problem with the other batches with rock mix. Anyway I guess I should have squeegeed the bubbles off the top before I left for 1.5 hrs. When I got back it was kind of rubbery so I scraped all the soft tiny bubbly crap off the top and now the rest is really hardening up good on its way to being a big old happy rock So one thing I think is mixing up a batch with epoxy and just fine sand you may have a problem with air bubbles. The rock mix did not have that problem. The average weight ratio of epoxy to filler on this was about 1 to 5.5. With the materials I used here adding much more percentage of filler was going to cause a dry and bad mix. In the pics here part of the fill looks wet but its not. When I slid the base off the bench by hand to weigh it I was like holy crap! I used my hoist to put it back on the bench Dave
    Attached Thumbnails Attached Thumbnails Epoxy-Granite machine bases (was Polymer concrete frame?)-base16.jpg   Epoxy-Granite machine bases (was Polymer concrete frame?)-base14.jpg   Epoxy-Granite machine bases (was Polymer concrete frame?)-base15.jpg
  • #607
    Jan 2007
    Texas!
    Oh one more thing- When the mix was curing it just barely got warmer than ambient maybe 10 or 15 degrees warmer than the temp here of about 75 this afternoon. The fill on this base is in 3 sections and I estimate the mix weight of the 2 long sections about 25 lb each and 15 lb for the square section. I did this all at once without stopping so its good to see there was no problem with overheating when curing the large amounts of epoxy. Dave
  • #608
    Gold Member walter's Avatar
    May 2003
    Nice work Davo!
    I think we may need to go with Larry's suggestion ("Removing entrapped air with a blow torch...")
    That reminds me, I need to buy a fire extinguisher.
  • #609
    Jan 2007
    Texas!
    Thanks Walter. Yeah and maybe do a flammability test with a small sample of epoxy outside and see what happens. I would hate to turn my project and the garage into an inferno. D
  • #610
    Sep 2006
    I don't know if anyone mentioned this but I've heard of using quartz lamps or something similar. The application was for post cured epoxy. Probably gentler on the Epoxy. I believe the slower the cure the better the characteristics. Just enough to promote the outgassing.
  • #611
    Registered lgalla's Avatar
    Jul 2006
    canada
    Walter you forgot the smilies.Actually the blow torch thing is mainly for the surface plate or thin sections, not for heating batches.If you need to lower the viscosity put the mix container in a tub of hot water.If trying the torch you move quickly over the surface.BTW a paint stripping gun works also.To quote Walter "nice work Dave"
    The rock batches naturally released air faster as the spaces are greator.A cheap air hammer may be a good vibrator.
    Sandi, Quartz is a slavic word.
    Bruno thanks for the link.I once wanted to say what we need is right under our noses.US silica and LV Lomas are good to deal with and offer bagged dry material.Some of the big guys only sell railcar loads.I think Lomas is also in Montreal and they have no problem with samples or one bag orders.
    Larry
    Quartz crystal sweeper
  • #612
    Jul 2006
    canada
    Atenman1 I think you posted a concrete vibrator source many many posts ago.Do you still have it?Harbour Freight has one for about $80 and there are other types on E-bay.Apparentally 30 seconds with one of these type units is enough for concrete compaction and air removal.
    Larry
  • Page 51 of 394 FirstFirst ... 414849505152535461101151 ... LastLast
    1. Index to "Epoxy-Granite machine bases" thread
      By walter in forum Epoxy Granite
      Last Post: 12-01-2011, 11:45 PM
    2. Replies: 13
      Last Post: 04-25-2011, 08:26 AM
    3. Polymer Concrete
      By ericdwilso in forum General Metal Working Machines
      Last Post: 09-14-2009, 02:00 PM
    4. Polymer Concrete Tests (PICS)
      By WilliamD in forum Mechanical Calculations/Engineering Design
      Last Post: 07-05-2008, 05:05 PM
    5. Free Granite for Machine Bases
      By DGoncz in forum Mechanical Calculations/Engineering Design
      Last Post: 09-29-2007, 02:36 PM
