Results 1 to 3 of 3
Thread: Will sharp sand suffice for epoxy granite ?
    Jul 2011
    England
    I am struggling to source the required aggregate for making epoxy granite here in the UK and was wondering whether I can oven dry builders sharp sand and use that ?
    The other question I have surrounds whether it is acceptable to make a 2700mm * 75mm * 150mm beam which I intend to use as the x- axis rail ?
    I was thinking that I should insert some reinforcing bar of some sort so as to give it strength, but someone suggested that you should not do this as it will cause cracks in the epoxy when it dries due to the epoxy shrinking ?
    Mar 2012
    Sweden
    Sand, don't know.
    Beam: all depends on what load you will put on it.
    Reinforcing: If it is the 2700mm long beam I would definitly reinforce it unless maybe, maybe not if it is supported all the way along its length.
    EG will not shrink if you use solvent-free epoxy as you should, It will cure in a chemical process, not dry up.
    Oct 2010
    England
    Hi Flanajb, I'm no expert in this field; I build reinforced concrete structures. The steel will not cause the concrete to crack; with shrinkage. The steel actually works completely opposite and stops the cracking; as we put 'anti-cracking' bars in corners; as shear force is applied more in corners and causes more cracking.
    Assuming it's 2.7m long by 75mm wide, 150mm deep; I would certainly reinforce with steel, and small little links, you will want a slightly larger aggregate would also help. Maybe a little single to give a bit more strength; sharp sand a little on the weak side. You might be able to tie some simple wire depending what sort of load you're putting on it.
    I'm no expert at all; but would aluminum not be a better material for your requirements; lighter, greater tensile strength?
    http://www.preciseformwork.co.uk
    http://www.preciseformwork.com
  1. Epoxy granite
    By slektning in forum Norwegian Club House
    Last Post: 06-29-2011, 03:57 AM
  2. Epoxy Granite "s Skeleton
    By hkxy in forum Epoxy Granite
    Last Post: 05-02-2010, 09:35 PM
  3. Seperate forum for Epoxy Granite
    By jhudler in forum Suggestions for the CNCzone.com site.
    Last Post: 04-30-2010, 08:38 AM
  4. New Machine Build- Epoxy/Granite Gantry Router
    By johnohara in forum Open Source CNC Machine Designs
    Last Post: 09-22-2008, 09:43 PM
  5. Epoxy/granite machine concept
    By Gizmot in forum Vertical Mill, Lathe Project Log
    Last Post: 02-28-2008, 03:46 PM
