Originally Posted by
brunog
Jestah,
It would be hard for me to confirm proportions of the items, not knowing the sizes and proportions within them, however one of my concerns is the 14-22 mm item: it is usually recommended the the thinnest wall be at minimum 5 times the size of the largest item. Not knowing what your design looks, 110 mm is quite large as a minimum wall size. Rebar and/or threaded rods will help only if your parts will work under tension, as EG, like concrete, is strong in compression.
Special care (processing) is required to make epoxy stick to aluminum, I suggest using steel instead.
Best regards,
Bruno
