Results 1 to 6 of 6
Thread: Epoxy Concrete Commercially Made Machines only
    May 2007
    HI All
    A great use of Epoxy Concrete:
    Other Hermle Machines also Use Epoxy Concrete.
    The brochure can be found at the Hermile website:
    http://http://www.hermlemachine.com/
    Direct Link:
    http://http://www.hermle.de/ablage/m..._EN_2008_2.pdf
    Cheers
    John
    Registered mmcp42's Avatar
    Dec 2010
    UK
    Quote Originally Posted by JohnMcNamara View Post
    snip...
    Welcome to Hermle Machine Company LLC
    Direct Link:
    http://www.hermle.de/ablage/med_0000..._EN_2008_2.pdf
    ... snip
    I fixed your links!
    May 2007
    Fixed again
    Thank You
    I fixed the image.....Strange I checked it was there the first time.
    Cheers
    John
    Dec 2010
    UK
    you had http:// in there twice
    Registered BobWarfield's Avatar
    May 2005
    Very cool.
    There's a local shop that has one of those machines (found it via Google). I'm tempted to call him up and see if he'll let me come by and check it out.
    Cheers,
    BW
    Try G-Wizard Machinist's Calculator for free:
    http://www.cnccookbook.com/CCGWizard.html
    May 2007
    More machines
    Hi All
    The AIEE Engineering exhibition just finished in Melbourne.
    There were four machines using epoxy concrete
    3 from DMG Mori Seki
    1 from ANCA a tool and cutter grinder
    More and more high end precision machines tool manufacturers are using this technology.
    Cheers
    John McNamara
    1. Replies: 4718
      Last Post: 05-15-2013, 06:26 PM
    2. Epoxy Concrete Aggregate Ratio Mixing Method
      By JohnMcNamara in forum Epoxy Granite
      Last Post: 05-12-2011, 08:52 AM
    3. Replies: 10
      Last Post: 04-30-2011, 02:09 AM
    4. Has anyone besides this guy made concrete mill parts?
      By slashmaster in forum Benchtop Machines
      Last Post: 01-21-2011, 06:18 PM
    5. Epoxy Granite In Practice (Mineral Casting, Polymer Concrete)
      By johnohara in forum Mechanical Calculations/Engineering Design
      Last Post: 03-27-2010, 01:16 PM
