This may not be of help Greybeard, but I'm going to suggest a different approach. My electric guitar has a Floyd Rose bridge, where the tuning is done by small 4mm screws, one for each string. The string is clamped then the tiny screw can be finger turned to give the correct spring tension.
You should be able to mass produce a system like this very easily, just clanp the string at both ends then have a fine thread screw to adjust the string tension either by direct pulling or by a slight leverage as used in the Floyd rose;
LinkBack URL
About LinkBacks
