Up till now, I've been planning to do a Mill using 8020 extrusions.
I have experience with 4" steel tubing filled with cement used to support the main central floor beam running down the middle of a house. The result is a much stronger support than if the 4" tubing were left empty. Adding plain old portland cement to the columm is cheap and easy. Soooo I've sorta been looking for a similar thing to do with 8020. (focus on cheap and easy filler mix)
I had been thinking of using something premixed and available from Home
Depot or Lowes or such until I stumbled across the postings here on E/G.
Finding huge I Beams in a local scrap yard at $0.15 a pound lets me construct a very strong frame quickly and it leaves lots of room for an epoxy filler to dampen vibration. With the design posted above, the accuracy of the machine would be in the welding and machining of the parts. Since I have access to a huge
CNC Mill, I'm confident things will come together well.
Soooo for this design approach, I just want a quick and easy filler mix.
What's a good inexpensive mix for this design approach?
Later posting will cover having the E/G do all the work instead of the
CNC mill.
