A few threads down, is a thread with 5000 posts which explains exactly what fillers to use, and in what ratios.
Hey guys, i was reading some nice posts about machines made from Epoxy and fillers like sand.
I found that is possible to use calcium carbonate, dolomite, sand...
Someone know wich will be the best combination to make an solid and not overweght machine using epoxy+fillers?
Thanks in advance
UCCNC 2017 Screenset
The aggragtes and fines used in concrete (cement) can be used in epoxy granit. Large stones 10-15mm down to fine sands graded to fill the voides. Sharpe stones add strength but make it harder to mix and work. Density is around 2200kg/m3 less than aluminium.
There are some different stones that can be used(?) in my area. These are;
- Quartz sand:
- A sand that is called "Silis" in Turkish. People use it on sand blasting.
- Lastly some kind of black sand. It is used to decorate floor of aquarium/fish tanks.
Would you use these as filler?
Suat
Proud father, C# developer, Model heli pilot, newbie free time machinist for hobby
I used two grades of quartz sand, and biggest aggregate was something like on your second photo, river sand. 8% to 10% slow curing epoxy, not vibrated, hand compacted with tools, and eveyrthing went well. Got the density of almost exactly 2 kg per cubic dm. Make sure to dry it well, as some bagged quartz can be little wet.
Basalt is the hardest and should be the best option, i think. The weight should also be a benefit. However, i could not find basalt in all grain sizes, thats why i mixed basalt, marble, gravel and quartz sand.
