Howdy all,
My new building is acquired and the city has signed the first of two inspections for the electrical in my workshop! I'm on the way towards real data!!!!!
Congrats to Walter on the pour of the Tabletop epoxy. I still think it would be easier to use the 37-127 and 37-606 as the surface as it's much lower viscosity will allow it to level better.
For metalworking precision, I disagree with Larry that you can mill the spoilboard to match the beam. If you rotate the cutter more than a tiny fraction of a degree from exactly parallel with the spoil board, when you mill them to one another, you will get a bunch of regular and unremovable ridges, the severity of which will depend on the size of the cutter.
As for the torsion box idea, it may solve wood working problems and make an okay base for a surface plate but I doubt however it will get the kind of precision required to build large metal parts accurately. It's a good start but I think it's an insufficient end.
--Cameron
