Go Back   CNCzone.com-The Largest Machinist Community on the net! > Events, Product Announcements and More > Environmental & Alternate Energy
Environmental & Alternate Energy Discuss Global Warming alternative energy etc here.
Old 11-19-2009, 11:10 PM
Eric MFG is on a distinguished road
Proper Disposal Of Used Coolant? I Have Bumb Qestions
Hi Guys,
This is a dumb question. I have a mill center that holds 40 or so gallons of coolant and use coolant MB50/50 (it's OK stuff will find better soon). What is the proper method of disposal of used coolant?
Thanks In advance!
Eric
Old 11-20-2009, 06:41 AM
DareBee's Avatar
Monkeywrench Technician
DareBee is on a distinguished road
Mine goes to an "environmental cleaning" service.
ie. the same type of company that gets oil at the auto shop and does the service on the parts washer and paint gun cleaning tank.
I think it costs me $100 a barrel and a huge pile of paperwork (initially) to setup the "waste generator account" with the government.
www.integratedmechanical.ca
Old 11-20-2009, 08:59 AM
As Darebee suggests the proper method is to a company licensed to take waste oil and oil contaminated water. It will cost a few dollars but if you just try dumping it down the drain, which is a dumb thing to do, and get detected it will cost more than a few dollars in most locations.
Old 11-20-2009, 10:16 AM
fizzissist's Avatar
fizzissist is on a distinguished road
We were going to construct a simple solar "still" where a simple, cheap, low power pump would circulate tired coolant over a solar heated surface to evaporate the water off, thereby concentrating the solution to minimize disposal volume...and cost.
When we proudly told the EH&S boys about our plan to save them money, we were told in no uncertain terms absolutely Not! You see, that was "processing", and we didn't have a license to process. That's their job.
See what happens when you try and save the Gubmint money??
Old 11-21-2009, 09:07 PM
mactec54 is on a distinguished road
If you used GreenCut you would not have this problem it's Biodegradable & 100% synthetic you never need to change it, just clean the chips out of your tank. & put the greencut back in, even tramp oil is not a problem the GreenCut just eats it up & keeps everything clean, I can supply this product in the US
Darebee the GreenCut is a Canadian product
Mactec54
Old 11-21-2009, 11:52 PM
HuFlungDung's Avatar
Moderator
What a crock! Evaporation of water is as natural as sunshine. Do you suppose they like collecting the fees on a per gallon basis?
Old 11-22-2009, 09:58 AM
Nastyzen is on a distinguished road
How about separating the mix by freezing the water out ?Anybody ever try this method?It`s about to get frigid up here and it`s free.
Old 11-22-2009, 10:04 AM
......When we proudly told the EH&S boys about our plan to save them money, we were told in no uncertain terms absolutely Not! You see, that was "processing", and we didn't have a license to process. That's their job...
If you are in a place that doesn't have excess sunshine buy on of these and don't tell anyone.
http://www.industrialairsolutions.co...vaporators.htm
http://www.coolantconsultants.com/evaporators.htm
Although I doubt it is worth the effort. We tried double skimming our waste coolant and evaporating the coolant that was now very clear of tramp oil but it was very time consuming to bring the volume down by more than about 50%. Now we just store it all in a big tank and call a tank truck once a year to take it away at a cost of about $1000.
Old 11-22-2009, 10:21 AM
fizzissist's Avatar
............ Now we just store it all in a big tank and call a tank truck once a year to take it away at a cost of about $1000.
I think 300+ days/yr of sunshine would be considered at least adequate...
No, the situation is, I'm perfectly confident, that we would be undermining someone's empire. The $1000 truckload is the key. You can't have a budget if there's no costs, and the greater the costs, the bigger the budget you can argue for.
Then, when you have a big budget, you have to have big budget administrators and administrative assistants, and more technicians to haul the stuff, and more trucks to haul more stuff,....ad infinitum.
Even if we only reduced volume by 50% it would have been a no-cost effort.....but nooooo........we were doing someone else's job, and that's just not any way to build a pyramid.
We have EH&S guys ...2 of 'em...come by every year and do an audit. In the audit they stick a small bar code label on each and every container of everything. WD-40, Dykem, the coolant, the Vactra, my bottle of Mequire's Plastic Polish, ........you name it, it gets a label. Everything.
All in the name of safety. Oddly, not that long ago, the fire alarm in the building went off and, being that it's noisy as hell, everyone went outside and stood around, waiting. Nothing happened. We waited 20 minutes. No firetrucks, no ambulances, no SWAT helicopters, nothin'. Finally, someone called the fire department. They didn't know anything.
Someone had been working on the alarm system a day or so earlier, and the alarm company that monitors our system didn't relay the alarm to the fire department because they thought someone was working on the system.
Penny wise, pound foolish.
Old 11-25-2009, 12:35 AM
ace of spades's Avatar
ace of spades is on a distinguished road
I am in South Africa, where do I get Greencut.
My problem is that there is only one company willing to take in soluble oil and unfortunately we must do the transportation and the company is about 350km (220miles) from us.
Greencut sounds like a genuine solution.
I must say that I really don't know what all the other machine shops do with their used coolants (dump in the sewer?)
  #11   Ban this user!
Old 11-25-2009, 12:58 AM
TOTALLYRC is on a distinguished road
Shameless plug needed.
Hi Mactec54,
your shameless plug for selling the green cut needed a web address or a the proper way to get it from you.
Mike
Old 11-25-2009, 07:07 AM
DareBee's Avatar
Why do they push the Biodegradable bit so hard? If it never needs changed - who cares?
I am looking into the product. If it as good as you claim - A trial is in order.
What is the changeover procedure? Last time I changed coolant the "bacteria" from the coolant before (which never stank) almost instantly infected the new coolant, making a big mess. They told me AFTERWARDS that I had to use a special solution (Biocide) to wash out with before change over.
Need Help!- Coolant Disposal gankoji General Metal Working Machines 3 06-10-2009 11:50 PM
Proper Coolant Maintenance/disposal dumptruck General Metalwork Discussion 1 01-22-2009 10:07 AM
Disposal of old coolant flatfnder General Metal Working Machines 6 08-22-2008 09:58 AM
Coolant ickification, and disposal Cowbell General Metalwork Discussion 1 05-25-2006 06:28 AM
etchant disposal Mcgyver General Electronics Discussion 6 08-22-2005 01:04 PM
