Go Back   CNCzone.com-The Largest Machinist Community on the net! > Events, Product Announcements and More > Environmental & Alternate Energy
Environmental & Alternate Energy Discuss Global Warming alternative energy etc here.
Old 08-17-2008, 11:25 PM
CNCadmin's Avatar
Site Owner
CNCadmin has disabled reputation
Wood gasifiers
Anyone ever build a wood gasifier?
Thank You,
Paul G
Site Owner-Webmaster-
Administrator
www.rfqwork.com
www.cnczone.com
www.welderzone.com
Old 08-19-2008, 01:51 PM
fizzissist's Avatar
fizzissist is on a distinguished road
I haven't built one, but thought this idea was interesting!
http://intotheborderlands.blogspot.c...revisited.html
Old 08-20-2008, 11:51 AM
fizzissist's Avatar
Personally, I don't have the fuel stock to make a gasifier economically feasibile....since it looks like you need 3-4lbs/kw...
Stumbled on this guy's homebuilt system. This looks like it would be a good place to start if you're serious.
http://www.clean-air.org/Ed%20Burton...ips_to_bio.htm
The little wood stove I posted earlier is a neat little idea, and simple to do..but I think a small nuclear cooker would be more promising. You can't have open flames anywhere I go camping anymore!!
Old 09-02-2008, 02:22 AM
harryn is on a distinguished road
The trick with gassifiers in general is to make sure what you are working with will really gassify - wood is an interesting example. With enough heat, about 1/3 of the wood will turn to gas, add some steam / water, and you can get up to about 1/2 with a really hot fire.
About 50 % of wood is lignin, which is a truly remarkable, 3 dimensional, highly stable material. From a gassifier perspective, it is a PITA, because it just won't. The guy in the link takes advantage of this fact by using his unit to make charcoal, which continues to burn in his little cook unit.
Interestingly, modern paper has very little lignin in it, so it is actually a better source of wood gas than wood itself. There is a fair amount of clay in paper, which will need handling - once again, a little steam helps, but it not a must.
Looking for someone to CNC Wood garypeck Employment Opportunity 0 07-01-2008 05:35 AM
from image to wood? shootingarts Machine Created Art 11 02-27-2008 11:27 PM
3D Carver for wood Roy... Commercial CNC Wood Routers 5 09-13-2006 02:16 AM
wood help JoSh.ExE WoodWorking 3 03-06-2006 02:38 AM
Not Wood but works like wood almost foamcutter WoodWorking 8 07-12-2005 05:14 PM
