Go Back   CNCzone.com-The Largest Machinist Community on the net! > Events, Product Announcements and More > Environmental & Alternate Energy
Environmental & Alternate Energy Discuss Global Warming alternative energy etc here.
  #25   Ban this user!
Old 12-12-2007, 10:16 AM
debogus's Avatar
debogus is on a distinguished road
light-bulb come on?
Drop the magnet down a copper pipe also.
Old 12-12-2007, 11:21 AM
miljnor's Avatar
S.N.A.F.U.
miljnor is on a distinguished road
Geof is right for the most part but there is "free" energy to be had sort of....
The universe is in constant flux and forces are acting on every particle at every moment. You can draw energy where there was seemingly none before.
We just haven't found a way to exploit the "free" (sort of) energy into a usable medium yet.
sources of potential energy: gravity, earths rotation threw magnetic field, previously mentioned Ionic particles, solar winds, etc....
Any thing that is moving threw space has the potential to supply energy, of course by using this energy you will slow or stop the particle/body, but I'm thinking, if its a body as big as a planet your not going to slow it down appreciably.
Armchair physics at its finest!
Maybe wishful thinking but I don't think so. After all nuclear energy is a "free"(sort of) energy because nature supplies it.
thanks
Michael T.
"If you don't stand for something, chances are, you'll fall for anything!"
  #27   Ban this user!
Old 12-13-2007, 05:04 PM
merl is on a distinguished road
debogus, I have a question related to your comments about the charging of capacitors from static electricity in the air.
Are you saying that storing the static electrical charge in a capacitor somehow turns it in to usefull electricity (voltage and usable amperage?) or do we still have to find some way to convert the static charge.
I have to run but, when I get back I want to lay out the beginings of an idea for power generation to see what you all think.
  #28   Ban this user!
Old 12-13-2007, 11:03 PM
debogus's Avatar
Not sure of potential stored in one , just that it was enough to hurt(kill)from static. Nor have I personaly discharged a static stored capacitor to even guess.
I was stating that static like carpet shock could be stored.
But how much , before you gained a usefull charge would be another question.
Van graph(?) generators work on the same principle .
But I'm just guessing that given a certain storage capicity ,discharged through a "something to step it down" gizmo
They electronicly step up low dc to high dc discharge voltages.save that to a capacitor then dump it to "BLOW STUFF UP" and make crazy strong short lived electro magnets.(wire goes bang)
Just seems to reason you could step it back down some way.
But like I posted earlier
You figuire out how and you'll be a conspircy story.
Tesla made high voltage into a electro magnetic wave and could rectify that back down.( but then again ,thats induction not static)
So the knowlege is probably buried with him.
Interesting idea though.
  #29   Ban this user!
Old 12-18-2007, 09:27 AM
wineslob's Avatar
wineslob is on a distinguished road
Originally Posted by vger View Post
My 6th grade science fair project was a 250KV tesla coil. Would light a flourescent (burnt out even) bulb about 30 ft away. It was a big tuned transformer at about 100 Khz basicly. Also destroyed off air tv and radio reception over quite a range. Definately not good for computer circuitry in the near vicinity either.
As for the Tesla turbine, here are a couple of links...
http://www.teslaengine.org/main.html
http://www.phoenixnavigation.com/
http://phoenixnavigation.com/ptbc/home.htm
As for using old oil wells for geothermal, you would want to drill them quite a bit deeper in most cases. California has some geothermal plants in production, but of course they are near the pacific "ring of fire" where thermal energy is available nearer the surface. One test well in austrailia back in 2003 was over 14,000 feet deep. Many older plugged wells are only 2000 ft deep. Just have to look around.
Steve
This very true. I've been to the geothermal area near Clear Lake Ca. I spent about a week there doing small steam line (2"-3" pipe) clean up for a company called Rain for Rent. The lines were used in the process of drilling the steam wells in the area. Some were upwards of 15,000 ft deep.
Geothermal is a filthy power source. The areas around the plants were covered with signs warning about the organic arsenic and other cancer causing contaminates in the areas. There were no animals or vegatation around most of the power stations (it looked like a moonscape around them). I was warned to stay away from the local streams.
Essentiality it was one of the most polluted and envriomentally ruined areas I've ever seen.
  #30   Ban this user!
Old 12-18-2007, 11:54 PM
debogus's Avatar
Good post
makes good old fashioned coal ,look pretty green
  #31   Ban this user!
Old 01-05-2008, 10:28 AM
vger's Avatar
vger is on a distinguished road
Green stuff
If it wasn't for CO2, plants would not be green. That's a scarry thought. The "Think Green" movement is ok, but we don't need to take it to excess.
Electrical energy stored in a capacitor is a static charge. That capacitor can take on many forms. In a VanDeGraf generator it is generally the smooth surface of the sphere on top. The larger the sphere, the more electrons it will store. Voltage is the force or pressure behind the flow, and Amps is the quantity of the flow.
Tesla was "transmitting" power via electomagnetic waves (radio waves). Not a bad idea, just the implementation of it was really not viable.
If we had to reduce the emission of greenhouse gasses to zero, we would not be able to burn or combine with oxygen any carbon based fuel. This would include wood (includes charcoal and wood products), coal, oil (includes plasitc, wax, and any oil product) and natural gas. We would also have to stop eating carbon based foods. We intake carbohydrates convert that to energy to live and expel the CO2 thereby produced through a process we call breathing. Not to mention the methane we expell from other areas of the body. Oh dear... we need to stop creamating our bodies too... and oops, I guess just the eventual decay of an embalmed body actually releases greenhouse gasses too... we need to stop dying !
Have a great new year
Steve
  #32   Ban this user!
Old 01-05-2008, 11:29 AM
sblocker130 is on a distinguished road
well seve i think the idea with anything is not to get carried away i agree with you on that one but the ice is outdated and we as a whole need to move on
sorry little off topic but relevant
Nikola Tesla Medal Engraved via CNC dcarr CNCzone Club House 11 02-23-2008 12:46 PM
