| Environmental & Alternate Energy Discuss Global Warming alternative energy etc here. |
#145
| Most of us have traveled from the intercity to the rural country side, or have spent the day under the shade of a great tree and noticed how much cooler it is. And most of us realize that if we add even a little warm water to an ice cube the ice cube will melt. So why is the concept of temperature change any different? I do not know about the effects of co2 but I know without a doubt that we continue to expand and create concrete highways and that the urban sprawl is at its highest point ever, sooooo we remove the trees--which add a cooling effect--and build buildings and highways which will scold you when touched or walked on.(The reflective quality alone, not to mention the ability to retain heat has to do something to the surrounding air). You know that if you come next to a building that is in the direct sunlight that the surrounding air is hotter, Why is this hard to imagine on a global scale?? How far fetched is the global warming due to co2, that is debatable, but as for adding to the global temperature by deforestation and urban sprawl, I don't think that any of us have much of a debate. As a side note--What if we live our entire lives thinking that co2 emissions is not contributing to global warming and we are WRONG?? What is wrong with trying to limit what we know is bad, Yah I know that cows and a thousand other thing emit tons of co2 daily but that should only be more of a reason to control what we can. Kind of like life itself--control what you can control and deal with the rest. Just a though. |
#147
| But it really does not matter whether it is a natural change or a man made change it is pretty well impossible to do anything about it. Even the IPCC gurus say that no matter what is done the current CO2 levels will continue to cause increases in temperature for about the next hundred years. The increase at the end of the hundred years will be less if CO2 emissions are cut in half but for the next fifty years the temperature increase will be more or less the same whether anything is done or not. At the same time these gurus predict that catastrophic irreversible changes will occur within twenty years if we do not do something. It does not compute...if we cannot have any influence ess than fifty years how can we have an influence in less than twenty years? And all this overlooks that it is impossible to reduce CO2 emissions by 50% without causing a mind boggling disruption in the world economy and everybody's way of life. Energy consumption is embedded in everything we do and the only way to reduce CO2 emission is to reduce energy consumption. Look at post 14 in this thread; Kyoto versus basic human rights It is a semi-flippant discussion but I have yet to find anyone who can find a flaw in the underlying premise.
#149
| What's wrong with burning fossil fuel and emitting CO2? Fossil fuels come from dead plants. These plants grew off CO2 in the air. When we burn fossil fuels, we put that CO2 back where it came from. If you want to "do something", plant some trees. |
#152
| BTW, plant and trees only produced oxygen when there is sunlight. I think we tend to forget this very important point. At night or when there is limited sun light, trees produce CO2 just like we do. |
#153
I can assure without a doubt there is less tree in Borneo now then there were in a 100 years ago. The same with the Amazon and other tropical countries. Why I l know? Just look at the amount of concrete that has replaced the acres of forested land. So I don't think there is more trees in North America now than there were in 1492. Where do you get this figure from? |
#154
I agree that my response was flippant - I was trying to make several points without restating them for the Nth time. CO2 is not pollution, but part of the natural cycle of energy exchange that happens between plants and animals. Yes, plant metabolism includes the oxidation of carbohydrates in the absence of light - how is that a problem? The fact that a tree becomes taller and heavier year after year is direct evidence that it has absorbed more CO2 than it has released, despite the lack of sunlight every night. CO2 is not toxic at low concentrations - heck, even oxygen is toxic at high concentrations: http://www.inspect-ny.com/hazmat/CO2gashaz.htm Yes, there is more CO2, but even a 100% increase would go unnoticed, and no GW fanatic is claiming that is going to happen. If the proportion of free oxygen in the air starts to drop significantly I would be concerned because this could indicate an imbalance; that too much oxygen is attached to other elements. Why don't they try and scare us with "plummeting oxygen levels"? Could it be because the CO2 increase is due not to new combustion, but rather to a release from the oceans that resulted from the slight temperature increase we are arguing about? When you burn hydrocarbons you create CO2 and water vapor. Water vapor is a much more potent greenhouse gas than CO2 and you can see its effect immediately - no waiting 100 years for a 1 degree change: Cloudy days are cooler, cloudy nights are warmer, yet nobody is complaining about the contribution of water to global warming. Why is that? To see the effect of water on GW models see: http://mysite.verizon.net/mhieb/WVFo...ouse_data.html I believe CO2 is no more a problem that water vapor and that even if we are contributing to a very small temperature increase, this is a good thing, rather than bad. Just how much CO2 can the earth take care of before the balance is tipped? The tipping point that we have been warned about can only be avoided by "immediate and drastic action", but cutting our CO2 emissions 50% won't have any measureable effect on GW until all witnesses present today are dead and gone. I smell a rat. I maintain that GW is a politically motivated issue used by the left to achieve their goals, much like the war on terror is used by the right to achieve their goals. ****************************************************************** More info on CO2 toxicity at: http://wasg.iinet.net.au/Co2paper.html CO2 Concentration: Comments 0.03% Nothing happens as this is the normal carbon dioxide concentration in air. 0.5% Lung ventilation increases by 5 percent. This is the maximum safe working level recommended for an 8 hour working day in industry (Australian Standard). 1.0% Symptoms may begin to occur, such as feeling hot and clammy, lack of attention to details, fatigue, anxiety, clumsiness and loss of energy, which is commonly first noticed as a weakness in the knees (jelly legs). 2.0% Lung ventilation increases by 50 percent, headache after several hours exposure. Accumulation of carbon dioxide in the body after prolonged breathing of air containing around 2% or greater will disturb body function by causing the tissue fluids to become too acidic. This will result in loss of energy and feeling run-down even after leaving the cave. It may take the person up to several days in a good environment for the body metabolism to return to normal. 3.0% Lung ventilation increases by 100 percent, panting after exertion, Symptoms may include:- headaches, dizziness and possible vision disturbance such as speckled stars. 5 - 10% Violent panting and fatigue to the point of exhaustion merely from respiration & severe headache. Prolonged exposure at 5% could result in irreversible effects to health. Prolonged exposure at > 6% could result in unconsciousness and death. 10 - 15% Intolerable panting, severe headaches and rapid exhaustion. Exposure for a few minutes will result in unconsciousness and suffocation without warning. 25% to 30% Extremely high concentrations will cause coma and convulsions within one minute of exposure. Certain Death. Last edited by dynosor; 11-29-2007 at 05:44 AM. |
#155
Donna |
#156
| How much fuel do humans burn compared to all the wild fires going on around the globe? We lament the loss of Amazon forest and would like to stop harvesting of "old growth", but if we leave large areas covered in closely spaced trees they will catch fire sooner or later due to man or nature and more will be lost than if we thin them out. Some tree seeds can only germinate after being exposed to fire. For instance: http://www.csu.edu.au/special/bushfire99/papers/kenny/ This suggest that fire and combustion are natural, and that humans burning fuels is not un-natural. If you must "do something", plant some more trees. Last edited by dynosor; 11-29-2007 at 05:47 AM. |
| Tags |
| emissions |
| V4 coming up | balsaman | Steam Engines | 26 | 08-08-2011 04:38 PM |
| Recent History Of Global Climate Change | NinerSevenTango | Environmental & Alternate Energy | 14 | 01-14-2010 11:08 AM |
| Leading Climate Change Experts Blame Hollywood for Spreading False Fears | Rekd | Environmental & Alternate Energy | 82 | 06-03-2009 10:19 PM |
| A Brief History Of Global Climate Change | Geof | Environmental & Alternate Energy | 36 | 04-21-2008 08:07 AM |
| How to change Tool change position(About MAZATROL T1 control) | liushuixingyun | Mazak, Mitsubishi, Mazatrol | 5 | 07-07-2007 03:58 PM |
