Go Back   CNCzone.com-The Largest Machinist Community on the net! > Events, Product Announcements and More > Environmental & Alternate Energy
Environmental & Alternate Energy Discuss Global Warming alternative energy etc here.
Old 02-06-2007, 12:51 AM
A Brief History Of Global Climate Change
Climate change was affecting Earth long before there were humans around to call it climate change and it will probably still be affecting the Earth long after humans are gone. It is only fairly recently in recorded human history that climate change has been recognized. The Vikings who settled Iceland and Greenland and even established a brief foothold in Newfoundland near the end of the first millenium did not know they were benefiting from a preceding warm spell that was starting to cool. Their descendants who starved in place or abandoned their colonies several hundred years later also did not know they were the victims of climate change in a cooling now called the Little Ice Age and it took several hundred years more before the idea that climate might vary started to enter into human knowledge. Now the warnings of CLIMATE CHANGE are ubiquitous as are the exhortations TO DO SOMETHING ABOUT IT. But when did it all start...human knowledge of climate change that is...what is causing climate change and can something be done about it?
Probably the first Climate Scientist, although this title was not used, was William Herschel around 1801 when he documented a connection between sunspot activity and wheat prices going back a couple of centuries. He speculated that changes in the sun's output with different levels of sunspot activity caused temperature differences affecting wheat yields: He was ridiculed. However, neither the wheat price/sunspot activity correlation nor additional observations that the coldest period in recorded history, the Little Ice Age, also coincided with an extended period of low sun spot activity known as the Maunder Minimum could be ridiculed away. But finding a convincing mechanism that could cause the global climate to change with sunspot activity was difficult; solar output does change with sunspot activity but by an amount that is so small it was not credible that it could cause a temperature swing on the earth of a maybe degree Celsius.
So climate change was observed but not recognised; in particular the biggest climate changes of all, Ice Ages in which vast areas of the world were glaciated had not even been conceived of. It was not until around 1837 that Louis Agassiz postulated that in the not too distant past, geologically speaking, vast icefields had covered Northern Europe. Agassiz was lucker than Herschel, he was not ridiculed, and the idea of significant climate change arose, however there were complications. Once the evidence for ice ages was recognised it became clear that they had occurred on a regular cycle going back millions of years. This presented a problem because the known variation in solar output was (supposedly) too small to realistically account for even little ice ages never mind the real thing. It was almost a hundred years before a mathematician proposed that cyclic changes in the Earth's orbital path, which varied its distance from the sun matching the glacial cycles, were responsible for the ice ages. These 'Milankovich cycles' are the best explanation currently available for Ice Ages.
But the problem of smaller shorter changes still existed; what causes them? Through the early to a bit past mid 20th century THE EARTH WAS COOLING! Then things changed and it seemed to be getting warmer and suddenly a CULPRIT WAS IDENTIFIED. Various gases or vapors in the Earth's atmosphere act to retain heat energy; the so called greenhouse effect. The most significant is water vapor H2O, the next carbon dioxide CO2 and the third methane CH4; of these three both CO2 and CH4 were increasing at the same time as global temperatures were increasing. OBVIOUSLY the cause of global warming was the increasing level of CO2, oh... and CH4 and these are produced by human activity; to paraphrase Pogo 'the culprit is us'. The complication that H2O is a much more significant greenhouse gas than either of the others was glossed over. Water is too difficult to deal with because if it is a vapor it is a green house gas but water droplets, when they are above a certain size, form clouds which can act like a sun shade and cause cooling. So ignore the water, ignore clouds, make nice simple climate models that show temperature rising in synchrony with CO2 levels and THE PROBLEM IS IDENTIFIED. Actually it is more a case of nice complicated climate models so nobody can figure out what you did so of course they cannot pick things apart.
But the sun is still there, still getting sunspots and interestingly enough for the last three or four decades has been very active sunspotwise; much more active than in the first half of the 20th century and throughout recorded history high sun spot activity has always correlated with higher global temperature. However, the direct change in solar output due to sunspot activity was simply not large enough to account for the temperature changes but in recent years other avenues of investigation have opened up. High sunspot activity increases the solar wind, the flow of charged particles emitted by the sun past the earth, causing enhanced aurora, sometimes power outages in northern latitudes and damage to communication satellites. And also interacting with another flow of charged particles that strike the earth and that are know as cosmic rays. Cosmic rays are very high energy particles and occasionally interact with other atoms transmuting them into unstable isotopes. Two such isotopes are Carbon 14 of carbon dating fame and Beryllium 10 of very little fame at all: Except to the scientists looking at ice cores and tree rings, dating them, doing analyses for Beryllium 10 and finding that back through history when sunspot activity was high beryllium 10 was low. And as an aside showing that sunspot activity does not always follow a nice regular cycle and shows variation over and above the long recognized 11 year cycle; with one of the periods of variation apparently being the past four or so decades.
So the climate story over the past three or four decades has been increasing temperature, the exact amount of the increase being debated and re-adjusted but still an increase, with rising CO2 levels the only accepted mechanism. While above everyones' heads the sun's enhanced sunspot activity, which in the historic record has always correlated with increasing temperature IN THE ABSENCE OF INCREASING CO2, this time is not responsible at all. The reduced cosmic ray flux is not causing a reduction in high level atmospheric haze or cloud because it it impossible to prove that cosmic rays, when present, cause clouds.
So the surreal conclusion is that a cause, human generated CO2, that did not exist during earlier periods of global warming is now the only cause of the current global warming, while a mechanism that did cause earlier periods of global warming, even though it may not be fully understood, now does not exist. This would make me just shake my head except that sunspot activity can go down. When it goes down temperatures will stabilize or fall slightly; past experience predicts that. If the envirofreaks and their tame politicians do push through MEASURES AGAINST GLOBAL WARMING they will take the credit!!!
P.S. I deliberately did not provide links. There are plenty of words to put into Google if someone wants to dig deeper.
Old 02-06-2007, 08:17 PM
Gold Member
Caprirs is on a distinguished road
That's interesting. I'll try to find the time to dig up some of the references and sources. Thanks. You da man.
Old 02-06-2007, 11:26 PM
fizzissist's Avatar
fizzissist is on a distinguished road
Originally Posted by Geof View Post
The reduced cosmic ray flux is not causing a reduction in high level atmospheric haze or cloud because it it impossible to prove that cosmic rays, when present, cause clouds .
Sorry, Dr. Bluster....but Giles Harrison and Dave Stephenson are going to be real disappointed to find out you haven't read their paper.....damned empirical evidence anyway.
Old 02-07-2007, 12:09 AM
NinerSevenTango is on a distinguished road
The tremendous amount of radio frequency radiation being continuously emitted into space by all kinds of radio transmitters since the 1930's has caused a modulation the electromagnetic field of the sun. This distortion increases the probability of magnetic storms on the sun's surface, which are known as sunspots. These sunspots in turn affect the plasma stream which interacts with the earth's magnetic field. As the temperature rises, the amount of information transmitted about global warming causes further increases in radio frequency radiation. It is a positive feedback mechanism which will continue to accelerate until something is done to stop it.
Emergency funding to research this imminent threat to the universe is needed immediately.
Old 02-07-2007, 12:13 AM
Gold Member
If we got rid of all the reality TV shows, would that help?
Old 02-07-2007, 03:30 AM
fizzissist's Avatar
Stop Drinking the Bong Water...
....And read the journals instead of the IPCC reports.
*Bill Nye, the Science Guy you ain't....
1. "Rising CO2 levels as the only accepted mechanism" is true for those who believe it is the only accepted mechanism, which many qualified atmospheric scientists, climatologists, oceanographers, glaciologists, etc. disagree with. Strong correlations with methane levels have been presented recently in peer reviewed journals.
2. The statement that "the historic record has always correlated with increasing temperature IN THE ABSENCE OF INCREASING CO2" simply isn't true.
Sun spot activity, while generally well correlated with increasing temperature over long time scales (the Milankovich Theory), has shown anti-correlations at times, over shorter time scales, pointing to other causes for short term changes ("short term" involving multi-decadal to century time scales). For example, between approximately 1930 and 1960, sunspot activity increased dramatically, as did CO2 emissions (due to WWII and post war reconstruction), while the temperature significantly dropped until the early 1970's, leading to the response by some climatologists in the 1980's (like James Hansen) that emissions would soon cause an ice age.
3. It is not impossible to prove that cosmic rays can encourage cloud formation. Svensmark and the team at the Danish National Space Center just did experiments that yielded compelling results in favor of a cosmic ray role in cloud condensation nuclei (CCN) formation, which needs to be studied further. Thats how science works. And oh yeah, the journal paper on that study passed_ peer review_ for the Proceedings of the Royal Society, a proanthropogenic global warming (AGW) journal. So real scientists give it credibility.
*..which is good too, since Richard Lindzen chewed him up and spit him out on Larry King Live...
Old 02-07-2007, 09:18 AM
Originally Posted by fizzissist View Post
..3. It is not impossible to prove that cosmic rays can encourage cloud formation. Svensmark and the team at the Danish National Space Center just did experiments that yielded compelling results in favor of a cosmic ray role in cloud condensation nuclei (CCN) formation, which needs to be studied further. Thats how science works. And oh yeah, the journal paper on that study passed_ peer review_ for the Proceedings of the Royal Society, a proanthropogenic global warming (AGW) journal. So real scientists give it credibility....
Yes I had seen accounts of the Danish study also the anti-correlations. It was a Brief History for goodness sake.
You should really try to learn the English language. How anyone can get the idea I support the AGW side from what I have written is beyond me. My sentence about the impossibility of proving cosmic ray promoted cloud formation was an ironic paraphrasing of the AGW side because this was the stance taken; maybe still is. If you want to be picky statements like this are correct; nothing can be proven in science one can only fail to disprove.
No go back and get your finger out, you can even move your lips, read it carefully again and try to understand the nuances.
Old 02-07-2007, 10:12 AM
"nothing can be proven in science one can only fail to disprove"
Is that a scientific statement?
--97T--
Old 02-07-2007, 10:33 AM
--97T--
I am not sure what you are getting at here. I was taught that the scientific method was to make observations, formulate a hypothesis and design an experiment to test the hypothesis. The design of the experiment should be such that it endeavours to show that the hypothesis is false or wrong. By this method no hypothesis is ever proven correct; it is only possible to say that it has not been proven wrong.
Are you trying to be helpful or just awkward?
Old 02-07-2007, 10:56 AM
Mostly just trying to be awkward.
What you describe as the scientific method is a much narrower context than the original phrasing.
I would contend that "science" consists of much more than hypotheses alone. Taken out of context, your phrasing could be interpreted as a blanket statement that perhaps you did not intend.
--97T--
  #11   Ban this user!
Old 02-07-2007, 10:59 AM
Mostly just trying to be awkward...--97T--
Pity, it is obvious you have the potential for better than that.
  #12   Ban this user!
Old 02-07-2007, 11:14 AM
fizzissist's Avatar
I got it now.
You were right, even though you were wrong, and I was wrong, even though I was right.
Starting to see the pattern now....
SpaceShipOne Makes History: CNCadmin CNCzone Club House 8 04-21-2008 09:59 AM
Keystroke History Help? Jclem2 General CNC (Mill and Lathe) Control Software (NC) 1 11-10-2006 02:22 PM
History jam1n CNCzone Club House 0 02-22-2006 03:09 PM
Haas Rotary History ARB Haas Mills 4 01-13-2005 02:02 PM
CAMback in Action: Post your Pix and get your business into our global Newsletter! CAMback General CAM Discussion 0 08-25-2004 07:54 AM
