Go Back   CNCzone.com-The Largest Machinist Community on the net! > Other Machines > Engraving Machines
Engraving Machines Discuss Engraving Machines here.
Old 01-17-2010, 07:07 PM
3v0 3v0 is offline
3v0 is on a distinguished road
Which software to engrave with CNC mill?
I need to engrave plaques using a small CNC mill. Black plastic over brass stock. I apologize if I am not using the correct terms.
Currently I am trying to find the right software. I read somewhere that some programs will raise a v bit to reduce line width. Some fonts need this. I have not seen any software to do it.
Currently I am playing with VisTool Engraving but there seems to be no support the program. The help files are missing. I have generated the gcode for a test that I will mill tomorrow. It is the sort of program I am looking for. Mostly I can take true type fonts and it will generate a pattern to cut out the interior.
I am still crawling on this but need to find my way soon.
Currently we have a diamond drag bit and a flat bottomed milling bit (D) .030 in. I like the idea of a rotating cutter more so then the scratch/drag.
What software do you recommend ?
Old 01-18-2010, 06:23 PM
3v0 3v0 is offline
Looking into Google Sketchup -> CamBam
I would like to hear how others do text engraving for plaques.
Old 01-20-2010, 03:37 PM
benji2505 is on a distinguished road
cnc mill
does your cnc mill want G-Code or does hpml code work?
Old 01-20-2010, 05:07 PM
3v0 3v0 is offline
I am using a MAX10 NC. It uses gcode.
I am getting closer. Using inkscape->DXF ->CAMBAM
Still a bit confused about the scaling. All the letters created with the 3D text tool seem to end up 1" tall in CAMBAM. I am looking for an easy way to scale the entire loaded file.
EDIT:
If one selects mm as the scale in inkscape the scaling is ok.
If one selects inches in inkscape cambam converts 1 mm to 1 inch.
Old 01-27-2010, 04:14 PM
try this
www.2linc.com
they have a decent software that translates everything into G01 commands, so it is highly compatible with most GCodes.
Other than that most CAM softwares have an engraving section.
how to engrave cob Mastercam 27 10-17-2008 02:51 PM
Need Help!- SOFTWARE for PHOTO ENGRAVE WITH DIAMOND POINT TOOL candino Engraving Machines 1 03-07-2008 11:33 AM
picture engrave meirmark WoodWorking 1 09-18-2007 09:31 AM
