Go Back   CNCzone.com-The Largest Machinist Community on the net! > Other Machines > Engraving Machines
Engraving Machines Discuss Engraving Machines here.
Old 12-25-2009, 02:26 PM
Buzz239 is on a distinguished road
g code program for making electronic panels
I am looking for a g code program to make electronic panels. I've been using DeskEngrave for the lettering. First I have to load the new label manually move to the new location reset the start point, engrave the label and do the process again.
If I could possibly find a g code program were I can load the engraving g code labels and set up the start point for each label.
Any help would be appreciated.
Buzz
Old 12-26-2009, 04:10 AM
TOTALLYRC is on a distinguished road
Buzz
Hi Buzz,
If you have G-code for each label you can just manually put together the gcode by cutting and pasting each code snippet in a larger gcode program.
I also see the you are using deskengrave, have you tried the deskcnc demo yet. It most if not all of the features of deskengrave plus many more.
The add text feature is probably what you are looking for. Give it a try and see if it does what you need.
Once your tools are setup in the tool table you should really be able to get going.
Mike
Mazatrol Program into a G Code Program fuzzman Mazak, Mitsubishi, Mazatrol 14 02-08-2010 03:55 PM
Need Help!- making program rewind bruiserba Okuma 9 01-19-2010 08:57 PM
How to add G41/G42 and D code to program?? tomekeuro85 GibbsCAM 7 04-18-2008 11:04 AM
scanner 2 g-code program auvecu CNCzone Club House 2 07-27-2007 01:59 AM
Bobcad G-code program watzmann CNCzone Club House 10 07-07-2006 10:42 AM
