| Engraving Machines Discuss Engraving Machines here. |
Hi there, I want to build my own floating head engraving spindle-nose Does anybody know a site where i can find detailled building plans and/or instructions to build this myself? Kind regards, Zoefie |
| Zoefie I have not seen such plans A "typical" engraving spindle mounted to the motion guide ways by means of a multi- bar linkage should do the trick. A polyurethane drive belt from drive motor to spindle meeting the flexibility requirement. The graver tip then must be regulated to extend beyond the rubbing guide nose the desired amount. Hmm pencil and paper...... Inspiration? http://www.visionengravers.com/produ...sories.html#si. The V-810 spindle offers floating capability. CalG Last edited by CalG; 12-15-2009 at 09:34 PM. Reason: Add link |
| Zoefie If I recall correctly, the floating function of the referenced spindle was accomplished by means of a spring loaded engraver tool holder. The tools are about 160 mm in length, and are mounted in the thru spindle at the top. either a solid threaded clamp for non floating applications, or a spring loaded clamp for floating work can be fitted. You will need to read through the literature/ parts list for details, my memory gets fuzzy with the passing years. CalG |
| These might point you in the right direction: http://www.vectric.com/forum/viewtop...=4772&start=15 http://www.patentstorm.us/patents/76...scription.html |
| Floating Z Head | tulsaturbo | Mach Plasma / Laser | 7 | 01-26-2010 11:40 AM |
| Need Help!- Floating head switch | millman52 | CNC Plasma and Waterjet Machines | 1 | 06-14-2009 08:17 PM |
| Floating Tap Head - Advice Please | UKRobotics | General Metal Working Machines | 3 | 10-23-2007 08:03 PM |
| Floating head on Kress router | zoltan | Mechanical Calculations/Engineering Design | 3 | 03-02-2007 07:52 AM |
| Floating Head Switch? | Redline | CNC Plasma and Waterjet Machines | 9 | 09-18-2006 08:21 AM |
