Go Back   CNCzone.com-The Largest Machinist Community on the net! > Other Machines > Engraving Machines
Engraving Machines Discuss Engraving Machines here.
Old 11-08-2009, 08:41 PM
rsharitz is on a distinguished road
Engraving Carabiner key chains
Hello Everyone,
I just became a member of the forum tonight and had a question about engraving carabiner key chains.
I just received a Epilog Helix 18 engraver from another High School in my area that lost their technology program.
I have the machine working, but was wondering how to engrave on irregularly shaped objects or objects that are not as easy to layout like glasses, pens and flat objects (and I already bought a few key chains to practice on)?
I tried to do a search, but couldn't find anything on layout (computer) and setup on the engraver.
Ron
Old 11-08-2009, 10:07 PM
kewlkiwi's Avatar
kewlkiwi is on a distinguished road
For one job I did the following:
Put the object on a flatbed scanner (with side to be engraved up)
Scanned it
In software, turned that into a silhouette (and checked the size)
" " converted that to an outline
Layout the desired engraving within the outline (on another layer)
Cut the outline in a sheet of acrylic
Drop object into outline
Engrave.
Since the 'cut along outline' step actually made the cutout very slightly larger, (half the width of the cut) this prevented the object being a tight-fit, and I also added a 'tab' to the outline - since the object wasn't much higher than the acrylic - to make it easier to take out after engraving.
Glasses and pens, of course, usually require a rotary attachment, depending on how much of the circumference you are planning to engrave on.
Bob
Need Help!- Working with Chains and Entities John Tribe LazyCam 1 06-08-2008 10:23 AM
Problem- all chains must be closed error v 21 woffler BobCad-Cam 2 05-30-2008 09:26 PM
Cable Chains Matt29c Linear and Rotary Motion 2 04-21-2008 01:20 PM
Help! Too many chains? bcnc LazyCam 2 11-23-2007 06:02 PM
RFQ - aluminum key chains and emblems (short run) joemartins Employment Opportunity 1 07-05-2005 10:14 AM
