Go Back   CNCzone.com-The Largest Machinist Community on the net! > Other Machines > Engraving Machines
Engraving Machines Discuss Engraving Machines here.
Old 07-31-2009, 04:26 AM
Mitsuboy is on a distinguished road
Laser Engraver Leaving Streaks when Engraving Mirrors! Any Suggestions?
Hello all,
I just got comfortable running my new Laser Engraver. I started Engraving the back side of mirrors. The first few turned out very nice. I'm starting to have a problem with streaking. You can see by the pictures that I am posting below. Something is wrong! I'm not sure if it's my settings or what! All of the optics are clean! My focal length is correct as far as I know. The only thing that I can think of next is maybe doing a beam alignment, But I don't have the tool that was supposed to come with the machine. I've contacted the Manufacturer of this machine, and although I have gotten several responses from them in the past, No response yet regarding this issue. Any help would be greatly appreciated.
ID:	85327   Click image for larger version
Old 09-07-2009, 10:10 AM
Barrys place is on a distinguished road
Working with mirrors can be a real pain. Inconsistent "coating" thickness is one of the biggest challenges I've found so far. In fact I don't like to do mirror work for just this reason.
I don't believe it's an alignment issue but one never knows.. What machine are you working with?
Are you running this dry or are you using the wet paper mask? I know I had streaking/edging issues where the paper dried when I failed to keep it consistently wet.
Barry
Newbie- engraving mirrors denbruno_09 Laser Engraving & Cutting Machines 29 02-26-2012 06:46 AM
Need Help!- streaks on laser engraved image identilase Laser Engraving & Cutting Machines 5 09-29-2011 02:37 AM
New Machine Build- CNC Laser Engraver, CNC Laser Cutting Machine, Dealer Wanted!!! oliver9866 Engraving Machines 2 12-15-2010 02:44 PM
Need Help!- Suggestions for laser engraver around $4000 TacPyro Laser Engraving & Cutting Machines 10 03-04-2009 05:21 PM
got Dahlgren engraver for retrofit- suggestions? lkasdorf DIY-CNC Router Table Machines 0 01-10-2009 07:58 PM
