Go Back   CNCzone.com-The Largest Machinist Community on the net! > Other Machines > Engraving Machines
Engraving Machines Discuss Engraving Machines here.
Old 04-13-2009, 11:32 PM
mgjones is on a distinguished road
What kind of engraving bits?
I am just starting out with a CNC mini mill (Sherline 5000 series inside an enclosure). The mill conversion is complete, the software is running and I've been playing with some GCode programs. Translation: I'm completely new at this stuff and need some help.
I would like to do some photo engraving as well as fine lettering. I've been looking at engraving bits and have seen two basic types. One is a one-piece bit that goes from a shank down to a flat, v-shaped sharp tip. The other, is a type of "holder" that holds a v-shaped, sharp tip.
What's "recommended"?
For the photos, should I use a v shaped bit, or a small diameter endmill?
What size is most useful/versatile?
Any recommendations would be appreciated.
Old 04-13-2009, 11:46 PM
dertsap's Avatar
Gold Member
dertsap is on a distinguished road
these are the v-bits i use and sell http://cnctoybox.com/shop/category_6...aram=cid%3D%26 , with the deeper depths that i do i prefer the 1/4" dia , personaly i like the 20 deg bits because i don't loose too much detail
this is the type of stuff that i do with them in my spare time
A poet knows no boundary yet he is bound to the boundaries of ones own mind !! http://cnctoybox.org
Old 04-14-2009, 01:15 AM
tobyaxis's Avatar
Moderator
tobyaxis is on a distinguished road
Like dertsap said, it depends on what kind of detail you need.
I use these when detail isn't that important.
http://www.harveytool.com/products/p...raving+Cutters
Toby D.
"Imagination and Memory are but one thing, but for divers considerations have divers names"
Schwarzwald
www.refractotech.com
Old 04-14-2009, 05:20 AM
Superman's Avatar
Superman is on a distinguished road
Your choice of tooling is dependant on the actual detail being machined, volume of material to be removed, actual material
.. a one-piece bit that goes from a shank down to a flat, v-shaped sharp tip.
Is a "D" bit, vee is one profile of many available
If a large open area then a "D"bit ( with the point removed )
for fine detail obviously a pointed tool. Some software ride up in the corners using the tool's taper to finish the shape ( CasMate was the software used )
Tool angles should also be looked at, as any thin detail will not be able to support itself, so draft would be used.
see
http://www.pilotltd.net/engraving.htm
and
http://www.antaresinc.net/
PS in metal, it is a nightmare changing and resetting blunt tools
Happy Engraving
Engraving acrylic, which bits LJN General Material Machining Solutions 4 05-10-2010 06:15 PM
Engraving Bits pike88 Engraving Machines 4 03-26-2009 05:12 AM
Need Help on Grinding Engraving Bits metalikha joel Toolgrinding & Toolgrinding Machines 9 12-22-2006 09:39 PM
Engraving Bits JMFabrications General Metalwork Discussion 3 03-15-2006 07:08 PM
Intro + engraving bits Swede General Metal Working Machines 7 02-07-2004 02:47 PM
