Go Back   CNCzone.com-The Largest Machinist Community on the net! > Other Machines > Engraving Machines
Engraving Machines Discuss Engraving Machines here.
Old 01-28-2009, 11:42 PM
sitzengruben is on a distinguished road
Z axis motor over heating
I work with a NH Vanguard 3000. The issue I am having is that the z axis motor is overheating. I have tried to swap the motor and it still over heats on a different motor. I doesn't matter what is hooked if it is off the z axis line of the harness it over heats. I have swapped the cables motors and even the control unit and it persist to over heat. Checked the voltage going to the harness off that branch and it matches that going to the other ones. The volt meter read 25 Volts DC though he motors are rated 5.4 volts DC but the documentation says it should put that out to the motors. In short I am now stumped. any help would be appreciated.
Old 01-30-2009, 10:29 PM
Torchhead is on a distinguished road
Define "overheating". Like it gets so hot the paint starts to smoke or it's just uncomfortable to hold you hand on it. The Z motor will run hotter because it has a constant load (gravity) whereas the other axis do not. Steppers are designed to run hot. They are copper wire and steel laminations. Not much to burn up.
TOM CAUDLE
www.CandCNC.com
Totally Modular CNC Electronics
Old 01-31-2009, 06:17 PM
I define overheating as runs hot enough to burn you, to make a burning smell, and also much hotter than the original motor. Not to mention the other two motors run cool to the touch not even remotely hot even after lots of engraving.
Old 02-02-2009, 01:45 PM
aminear is on a distinguished road
you may have a problem with your driver board. It senses current through the motor and has current limit built into it to limit that.
Take a look at a datasheet for the L297 &L298 stepper motor driver chipset.
It will show a typical setup and the resistor size it uses in the sensing circuit to control the current limit. I would guess you probably use this chipset on your drivers, that is the type on the vanguard 3400.
Arnie
Old 02-06-2009, 02:37 PM
Where can I find the Afformentioned Data Sheet. I don't have a lot of documentation floating around for this thing.
Old 02-09-2009, 04:10 PM
just google L297 on the web, you can also open the machine and look to make sure that is one of the chips on the driver board.
Old 09-20-2009, 01:53 AM
badger05 is on a distinguished road
I have just read elswhere in this forum about the bearings on the vertical alignment shafts being gummed up. Has this been checked?
Need Help!- Induction Heating _WALLACE_ Welding, Brazing, Soldering, Sealing 13 07-11-2009 08:13 AM
heating source for 48x48 VF-1/4 ABS edwardpic Vacuum forming, Thermoforming Etc 7 06-21-2007 03:36 PM
LMD18245T heating phantomcow2 Stepper Motors and Drives 9 07-28-2006 06:06 PM
Help with over heating gary-cook General Electronics Discussion 12 05-15-2005 02:35 PM
strange stepper heating Stevie General Electronics Discussion 5 05-21-2004 10:03 PM
