Go Back   CNCzone.com-The Largest Machinist Community on the net! > Other Machines > Engraving Machines
Engraving Machines Discuss Engraving Machines here.
Old 11-02-2008, 11:47 AM
Bob La Londe is on a distinguished road
EMC2 & Image to G-Code
Anybody running EMC2 with Image to G-Code?
I was justing looking at some of the work done with it on a 3 axis router, and was totally blown away. Its a 695 Meg download, and as near as I can tell its Linux based, but it may be worth setting up and dedicating a Linux box to run it.
http://lumenlab.com/2008/10/pumpkin/
Old 11-02-2008, 03:27 PM
Image to G-Code with EMC2. I downloaded and burned a CD, and I am at a loss. The OS loads and runs fine, and the EMC2 files are all intact, but I don't understand how to use the Image to G-Code program. When I looked at the refferences it looks like a command line program. ie:
program paramater data output
Is that correct or am I missing something?
Bob La Londe ~ Owner of two and a quarter G540s.
www.YumaBassMan.com
Old 11-03-2008, 12:55 AM
budP's Avatar
budP is on a distinguished road
http://www.linuxcnc.org/docs/2.1/htm...ode/index.html
try this
budP
Old 12-14-2008, 08:44 AM
pjpj410 is on a distinguished road
i to downloaded ubuntu 8.04 live cd to check out this image to g code program and cant get it to run.I found the instructions for it but dont fully understand them.
first it says to do this
Add the following lines to the [FILTER] section of your .ini file to make AXIS automatically invoke image-to-gcode when you open a .png, .gif, or .jpg image:
PROGRAM_EXTENSION = .png,.gif,.jpg Grayscale Depth Image
png = image-to-gcode
gif = image-to-gcode
jpg = image-to-gcode
where is the filter section of my .ini file loacated at?also i dont see a program called axis anywhere.I tried the command line and it just says file not found.
Old 12-14-2008, 04:52 PM
123CNC is on a distinguished road
GUI or gooey
Axis is one of the GUI options in EMC2. I think it defaults to TkEMC. Look under the [DISPLAY] section of your .ini file.
Not at a Linux box right now, but [FILTER] should be another section in your ini. You can just add in it in, but I don't recall what else is under that section. Perhaps someone else can shime in.
Old 12-14-2008, 07:30 PM
where is the ini file located?
Old 12-14-2008, 10:22 PM
Again, not near a Linux box. I will try my best from memory.
If you have installed Ubuntu and EMC2, and have started EMC2 and saved a configuration at the "Copy COnfiguration?" prompt, you should find all your configuration files from your main menu PLACES, HOME FOLDER/EMC2/CONFIGS.
If you chose BOSS or say STEPPER configuration, the ini would be BOSS.ini or STEPPER.ini.
Hopefully someone logging in on Linux or has a better memory can chime in.
POW-MIA Image G-Code Conversion rcazwillis G-Code Programing 4 05-11-2011 09:45 AM
image to g-code Mr Bits LinuxCNC (formerly EMC2) 6 07-28-2008 03:32 PM
Mirror image G-code johny0407 G-Code Programing 10 02-16-2007 03:57 PM
Best image to G code software metalhacker General CNC (Mill and Lathe) Control Software (NC) 10 10-19-2005 09:27 PM
image to g code NickLatech Mach Software (ArtSoft software) 1 03-18-2005 01:43 PM
