Go Back   CNCzone.com-The Largest Machinist Community on the net! > Other Machines > Engraving Machines
Engraving Machines Discuss Engraving Machines here.
Old 09-14-2008, 11:06 AM
Etches is on a distinguished road
Unhappy 35 Watt Laser Engraver
Hi! I'm new to the forum and hoping someone has a solution. I have a 35 Watt Vytek Laser engraving machine that they no longer make. (Tile Bandit)
As the laser is engraving, my table is raising by itself! Not sure if the buttons are sticking or what? Anyone have this experience before?
I have jobs pending and am a bit frustrated!
Thanks in advance if anyone has any ideas...
Beth
Old 09-15-2008, 06:16 AM
DaveDoesIT is on a distinguished road
Hi Beth,
Can't help with the problem, but the brute force solution could be disabling the raising mechanism. If it is raised and lowered by an electric motor, then insert a switch that cuts the power to the motor when you have it at the height you need.
If it is raised by air, then put in a small ball valve to do similar.
My guess is it is raised by an air cylinder and the solenoid valve that controls the "up" part of up/down is leaking air through to the cylinder.
Dave
Synrad 50 watt laser KTP Laser Engraving & Cutting Machines 26 11-11-2011 02:38 AM
Marking Stainless using CO2 laser 60 Watt Huahahahahaha Laser Engraving & Cutting Machines 21 11-05-2010 08:10 PM
Artcut JSM 40 watt laser ccroyscuba Laser Engraving & Cutting Machines 11 09-17-2009 05:40 PM
Why buy a Laser cutter when you can modify a laser engraver. spacifique1 Laser Engraving & Cutting Machines 7 08-13-2007 02:39 PM
60 watt engraver- opinons? replicapro Laser Engraving & Cutting Machines 10 05-14-2007 07:41 PM
