Go Back   CNCzone.com-The Largest Machinist Community on the net! > Other Machines > Engraving Machines
Engraving Machines Discuss Engraving Machines here.
Old 09-05-2008, 04:00 AM
Daz620UK is on a distinguished road
Gravograph VXM Control Help?????
Hi New to the forum but I,ve been reading posts now and then and now need to get started and could do with some help and advice.
Well here goes:
I have a Gravograph VXM engraver machine is in good mechanical condition. I know its previous history of 14 years light use as I was responsible for its mechanical maintenance.
I bought this machine when the company moved and closed its UK production facility.
I wish to use the machine for light engraving but I have a problem in that the Computer control is no longer working Why? I have no idea!
Question is would I be able to plug in a standard windows based software package and PC and be able to get it working, or would I need to use a new stepper control board etc and do away with the exisiting machine electronics etc.?
Any help direction would be welcome.
Thanks,
Old 09-05-2008, 12:57 PM
aminear is on a distinguished road
Daz,
From the work I have done one these so far it looks like it may be possible that rewiring the input will be all that is needed. I am in the middle of converting a Vanguard New Hermes 7000 and I have done a 3000 already.
They were normally run under the Gravograph software.
See the recent posts in this section.
I am running my 3000 machine on Mach3 software on a PC.
Old computers have a nasty habit of dying when the CMOS battery dies, you loose the info in your cmos, some of the batteries will also leak out corrosives that can attack parts of the motherboard rendering it useless.
Arnie
Old 09-05-2008, 03:39 PM
Originally Posted by aminear View Post
Daz,
Arnie
Arnie, Thanks for the reply. Yeah I,ve now had a look at the other threads and will follow them also as they do look similar. I will try later to post some pics of what I have here.
Old 09-06-2008, 09:15 PM
57phillip's Avatar
57phillip is on a distinguished road
Hey Daz, and all,
This is Phil, Arnie is working on my control system, and I am playing around with mach3 as I wait to have a machine hooked up to it. I get a message when loading mach says "contact Brian Buffer Error" I assume that means Brian Baker but I am not sure how or if I should contact him. If anyone knows what BUFFER ERROR means and correction procedure to follow I would welcome the help. By the why I bought GraveGraph 98 software for the Vanguard 7000. It is DOS purely, but if someone wants to try it on their new Hermes machine just for kicksor testing, I will loan it to you as I will not be using it. If you read some of the threads here in engraving machines you can find out why I am not going to use it.
Phil,
Old 02-25-2009, 11:55 AM
tr59 is on a distinguished road
Did you get anywhere with the Gravograph VXM?
Hi - I saw your post about running an old Gravograph VXM from a PC, and wondered whether you had managed to do this, or if you are making progress. We have a 17 year-old machine that still works fine, but it would be much better if it could be run from a PC.
Any help would be much appreciated.
Cheers
Terry
Old 02-25-2009, 12:24 PM
Terry,
I am running my vanguard 3400 straight from the parallel port on my pc. It is a matter of rewiring and some jumpering. It works great now. I do 3d, using vectric cut 3d, vcarve pro, photo vcarve, running Mach3 as the control program.
For anyone who has done the wiring mod I detailed you will also need to jumper the opto isolators on the ep3400, they are too slow, I was losing steps. Just clipping the opto's leads and running a jumper across them cured the lost steps.
Arnie
Old 03-03-2009, 01:18 PM
mdwuk is on a distinguished road
Smile VXM upgrade
There are various ways of upgrading your VXM to run off of a PC or interface box. Depending on the software you chose to create the job and the price that you wish to pay will determine the best route to take. You don't have to do away with your top electronics board if this is still working ok, just use this as a power rack. I have helped to upgrade many of the Gravograph VX range over the years. If you want more details please let me know.
Old 04-17-2009, 07:57 PM
ATE ATE is offline
ATE is on a distinguished road
I'm running a couple of VX machines with the old vx computer, but the HD in this unit is on its way out. I want to come up with a way of keeping these machines running, your help would be greatly appreciated.
Old 04-18-2009, 04:09 AM
Smile Gravograph upgrade for ATE
Priority!! - If your hard drives are failing save any important jobs you have on this to floppy disc.
Hard drive VX controller can be deconverted back to floppy only with just a set of PROMS, but obviously this makes your machine slower to program.
A few alternatives:
Gravograph do interface boxes - expensive!
We do a conversion unit - see website www.microwhite.co.uk
You can get software to convert an old PC into an interface box - please contact me direct if you wish for more details
All of the above work off a variety of design software i.e Engravelab, Gravostyle, Vectric, VCarve, Newing-Hall JLS
Mervyn
Old 04-24-2009, 04:34 PM
procomp is on a distinguished road
486 Motherboards
We still supply 486 motherboard assemblies for some Gravograph/New Hermes machines. http://www.esapcsolutions.com/ecom/m...ache-p-81.html
You can see the bare board above or call Larry at +1 561-226-1309 for more info.
Tony
Electronic Solutions Associates
  #11   Ban this user!
Old 06-06-2009, 07:43 PM
twistedgrilles is on a distinguished road
Hello I have a hermes Vanguard 7000. I would like to use it with mach 3 i purchased this breakout board:
http://www.cnc4pc.com/Store/osc/prod...products_id=46
I am wondering if anyone has a wireing diagram for this machine so I can install this board. Please email me with any info.
Thanks, Adam
tampajerseyhut@hotmail.com
  #12   Ban this user!
Old 06-14-2009, 12:34 AM
LOUIS-L is on a distinguished road
gravograph vx engraver
Hi everyone
I have a very old vx engraver (about 15 years I think) The whole system is functional, but the floppy drive has given up the ghost. I tried replacing it with a standard floppy drive but without success. I t seems that this a special type of drive. Does anyone have any ideas. I noticed that a couple of guys mentioned hard drives in relation to VX machines. My machine does not have a HD. I would like to be able to add one later if I manage to cet the floppy problem sorted out.
Any advice will be appreciated.
thanks........Louis-l
Need to replace Dynapath 20 control with new control Cycle Start Knee Vertical Mills 3 08-08-2010 03:14 PM
Need Help!- Seig x2 Speed Control and c6 Control Board skmetal7 Benchtop Machines 2 04-21-2008 03:17 PM
15i control help for (AiCC) (hpcc) high precision contour control programming gibbsmaster Fanuc 2 12-28-2007 09:57 AM
Using Flashcut CNC Spindle rotate card control to control laser power pyroplotter FlashCut CNC 0 10-15-2007 09:46 PM
BobCADCAM Layer Control / Snap Control jonbanquer BobCad-Cam 0 01-21-2006 03:10 PM
