Go Back   CNCzone.com-The Largest Machinist Community on the net! > Other Machines > Engraving Machines
Engraving Machines Discuss Engraving Machines here.
Old 08-08-2008, 10:31 AM
smallblock is on a distinguished road
LOOKING FOR HIGH SPEED ENGRAVING MOTOR
I want to do some engraving on my Shopmaster machine. The stock spindle is rated for about 3000 rpm and the big cast iron pulleys would limit any speed increase. My idea is to make a mount attached to the quill to hold a high speed motor. Ideally it would have a collet system or at least a single collet to hold the tools. Could anyone point me to a source?
Thanks in advance
Old 08-08-2008, 11:28 AM
LeeWay's Avatar
LeeWay is on a distinguished road
Air driven die grinders would do, but are noisy. I just installed a small trimmer on my mill and it is a little loud, but tolerable.
There are some high speed spindles here. Here is another source.
It really depends on what you want to spend and the accuracy you expect.
http://www.cnczone.com/forums/showth...t=32609&page=3
Lee
Old 08-08-2008, 03:04 PM
Thanks,
I have an air powered toolpost grinder- works fine, but like you said- pretty loud. Is that Rigid unit an AC with variable speed? Its what I had in mind, just for occassional use.
Old 08-08-2008, 05:24 PM
LeeWay's Avatar
It is a little VS laminate trimmer router. AC. I clocked it's speeds at 20,000 RPM no load low speed up to 31,000 RPM in high. It is real quiet in low speed.
Lee
Old 09-10-2008, 07:07 AM
jariou is on a distinguished road
You may want to consider the HF 1/8" Air Micro Die Grinder here:http://www.harborfreight.com/cpi/cta...emnumber=47869
It goes to 56,000 RPM and the air consumption is only 2CFM at 90 PSI. It is also fairly quiet. Oh and it is cheap too. You can get it for $9.99 every few months. Even at regular price it's real cheap.
I have seen this mounted inside an R8 spindle on a mini-mill for a similar application as yours.
Jacques Rioux
High Torque , High Bandwidth Motor or Servo mastabib Benchtop Machines 0 09-26-2007 02:09 AM
Engraving with High Speed Spindle MichaelHenry Tormach PCNC 7 06-27-2007 07:25 AM
High speed spindle... how high? jonesja2 General Metal Working Machines 0 06-04-2007 07:18 PM
High Speed Spindle for Taig - Brushless Motor? GammaWill Taig Mills & Lathes 14 03-29-2007 03:43 AM
