Go Back   CNCzone.com-The Largest Machinist Community on the net! > Other Machines > Engraving Machines
Engraving Machines Discuss Engraving Machines here.
Old 06-28-2008, 10:33 PM
stratcat50 is on a distinguished road
1/4" collet to mount on 8mm motor shaft.
I'm looking for a collet or chuck that will mount directly to an 8mm D-shaft
or round shaft. (I could cut off the D shaped part.)
Does such a thing exist? All I've found is tapered and threaded units
Thanks for any info,
Emory
Looking for a Coupling for 1/2" motor shaft to KR33 6mm shaft DonW DIY-CNC Router Table Machines 7 03-17-2008 03:58 PM
1/4" Laminate Trimmer Collet Adapters? vacpress DIY-CNC Router Table Machines 3 02-25-2007 11:09 PM
Motor mount plans? wilfreeman Benchtop Machines 15 01-25-2006 11:43 AM
Will 63" long Rail sag without using shaft support? starCNC General Metal Working Machines 5 08-04-2004 08:29 AM
router with 1/2" collet balsaman DIY-CNC Router Table Machines 7 06-04-2003 12:52 PM
