Go Back   CNCzone.com-The Largest Machinist Community on the net! > Other Machines > Engraving Machines
Engraving Machines Discuss Engraving Machines here.
Old 04-28-2008, 04:09 PM
fretsman's Avatar
fretsman is on a distinguished road
14.77 Spring Loaded Engraver
Just thought I'd pass this along. I've seen a lot of spring loaded engravers and I've been wanting to make one myself someday. Well today I had a "duh" moment and thought of my micro tapping guide!! I pulled it out, loaded it up in a collet, and away we went! The plunger is tight and has a beautiful slip fit (for now lol!) and has a very strong spring as well. I did not turn the spindle on for this.
I set it up to take .002" and used 2 passes and it really works VERY well. Here's the link to the actual product:
Description:
Micro Tap Guide Type: Micro Tap Guide Tap Size Range: #10 - 1 Length: 3
Type:
Micro Tap Guide
Tap Size Range:
#10 - 1
Length (Inch):
3
Shank Diameter
(Inch):
1/2
Big Book Page #:361
http://www1.mscdirect.com/CGI/NNSRIT...60523&PMT4NO=0
Sorry about the pics, but I figured you could get the idea.
ID:	58613   Click image for larger version
ID:	58614   Click image for larger version
ID:	58615   Click image for larger version
Dave->..
http://tinyurl.com/DLAManufacturing
Old 04-28-2008, 06:44 PM
jhowelb is an unknown quantity at this point
Educate me, what size bits will fit in there?
"Error of Opinion may be tolerated where Reason is left free to combat it." - Thomas Jefferson
Old 04-28-2008, 07:36 PM
fretsman's Avatar
There are no "replaceable" bits as it were, as these are not intended for engraving. Have a look at the catalog page for the description. The points could be sharpened as needed though.
Dave->..
Old 04-28-2008, 07:53 PM
Stepper Monkey is on a distinguished road
He's basically just using a spring loaded tapping guide as a form of non-rotating scratch engraver. Actually a very nice bit of repurposing there, it seems like a good idea in a pinch or for occasional use. Unfortunately, it would only work as a non-rotating engraver, it doesn't have any ability to interchange bits, and it wouldn't be as clean or consistent of engraving, last as long as a tool, or do harder materials. It would however, take a common and inexpensive tool and serve many peoples intermittent engraving needs in soft materials if you didn't have the need for a true engraving setup.
Old 04-28-2008, 08:21 PM
fretsman's Avatar
Thanks for explaining it much clearer than me, stepper. It actually is a very clean scratch and has that "diamond" scratch effect to it as well. The points on these are hardened so it should be interesting to see how long it lasts for me. I like this application for the half hard brass as it's the most success I've had with this particular material. I usually use single flute carbide bits but in this brass I get some nasty burrs that just look horrible at times.
Dave->..
Spring loaded graver drawing fatal-exception Engraving Machines 1 04-20-2008 08:24 PM
Spring Loaded Engraving Tool djh82uk General Metalwork Discussion 7 01-10-2008 11:35 PM
THC Floating head needs to be spring loaded? Normsthename CNC Plasma and Waterjet Machines 3 12-12-2007 08:44 AM
spring loaded rack and pinion dgalaxy CNC Plasma and Waterjet Machines 4 12-03-2006 12:49 PM
Spring Loaded Rack and Pinion request ty1295 CNC Plasma and Waterjet Machines 1 02-08-2005 12:15 AM
