Go Back   CNCzone.com-The Largest Machinist Community on the net! > Other Machines > Engraving Machines
Engraving Machines Discuss Engraving Machines here.
Old 02-11-2008, 10:15 AM
meisje08 is on a distinguished road
Is anyone willing to make me a spring loaded tool holder?
Is anyone willing to make me a spring loaded engraving tool holder? I've seen the one for $300-400 and that seems a bit pricey for me. I will be engraving text on 3" x .75" brass plates with a rotozip or similar, so it needs to be accurate. I have paypal and would like to get one soon if possible.
thanks
Old 02-14-2008, 08:36 PM
socalcnc is on a distinguished road
Spring Tool
HEY, I need one also. email me if someone is making them. wirewerks@verizon.net Thanks
Old 02-14-2008, 09:51 PM
fatal-exception's Avatar
fatal-exception is on a distinguished road
I have made 3 of them now, but they are used for shallow engraving with the spindle off. ( drag engraver) got the idea from the machinists bedside reader. They work perfectly with 0 backlash. Nice tool to have.
I could share my autocad drawing, or just make you one. I'll post pics later.
Paul
Old 02-15-2008, 10:13 AM
djh82uk is on a distinguished road
Ha ha thats wierd timing, ive just this very minute almost finished my prototype for a spring loaded engraving tool, it's going to need some refinement and I have no idea on what springs to use.
Below is my example, im not too happy with the design at the moment, it was more a proof of concept, the nuts are to be replaced later with nylon lock nuts and threadlock, I also would rather it if the bit holder was of a collet type design, but im still learning with my lathe.
If anyone has any design advice it would be welcome.
Once the design is improved and proven I may sell them.
Ive been thinking of using dremel style collets, but making the bit holder myself, still struggling a bit with threading on the lathe.
I ran it for over an hour at 30,000rpm (with me out of the workshop due to those nuts) and it was fine, as for accuracy I was really quite impressed, could see no blurring and it left a pin prick indentation from where it was running, the in prick was the same size as the end of the bit.
I am however still learning and probably have a long way to go.
My main use will be for pcb's where this is very little lateral force, would'nt like to say how it would cope with aluminium etc.
If I can get a 6mm and 3.175mm barrel lap I think it will be better, I also think the collet system is a must, aswell as a better design for the bar that runs up the slots, perhaps split pins or circlips, but I have not found any small enough.
The pcb was done before I made the tool. just so you can see they type of work i will be doing with it
DJH
Name:	engraving tool.jpg‎
ID:	53379   Click image for larger version
Old 02-15-2008, 11:28 AM
Oldmanandhistoy is on a distinguished road
Hi DJH,
PCB looks good and so does your spring loaded tool. Did you try that centring devise I posted a link for and if so what did you think?
John
Old 02-15-2008, 12:41 PM
I most certainly did, it's still a little bit of a struggle and the line you align it with is a little bit thick, but it definatley helps, still not dead on but the end slides up fairly smoothly, probably better if I could find an 8mm chucking reamer/barrel lap
DJH
Old 02-15-2008, 12:43 PM
Originally Posted by djh82uk View Post
DJH
Cheers
Old 02-15-2008, 12:51 PM
LeeWay's Avatar
LeeWay is on a distinguished road
What is the purpose of a spring loaded cutter. Is it kinda like THC on a plasma cutter? It will allow you to etch PCB's that aren't perfectly flat?
Just curious. Thanks.
Lee
Old 02-15-2008, 01:09 PM
Yep thats it LeeWay
Ive found it near impossible to get pcb flat with various different methods, it only needs to be out by a little bit to mess it up.
DJH
Old 02-15-2008, 01:13 PM
DJH,
How do you plan to regulate the depth of cut with the pictured design?
John
  #11   Ban this user!
Old 02-15-2008, 04:48 PM
well, it's the same principal as the ones sold by 2linc.com for a lot of money, once the correct spring is selected, although the force is not linear, it seems linear enough in that regardless of height, there is just enough force to go the required depth.
Im going to fit a tensioner in the top so I don't have to keep swapping springs.
Ive never used one before, but i have seen one that was engraving a 22mm copper pipe over about 100 degrees of it's surface, and the depth was the same as far as i could tell, we opened his tool up and it was just a spring and a form of collet.
Hope that makes sense, theres no harm in me trying it anyway
DJH
  #12   Ban this user!
Old 02-16-2008, 08:35 AM
Thanks, you will have to let us know how it performs.
DIY spring loaded engraving tool holder cut more Engraving Machines 25 12-07-2009 01:34 PM
Spring Loaded Engraving Tool djh82uk General Metalwork Discussion 7 01-10-2008 11:35 PM
THC Floating head needs to be spring loaded? Normsthename CNC Plasma and Waterjet Machines 3 12-12-2007 08:44 AM
spring loaded rack and pinion dgalaxy CNC Plasma and Waterjet Machines 4 12-03-2006 12:49 PM
Spring Loaded Rack and Pinion request ty1295 CNC Plasma and Waterjet Machines 1 02-08-2005 12:15 AM
