Go Back   CNCzone.com-The Largest Machinist Community on the net! > Other Machines > Engraving Machines
Engraving Machines Discuss Engraving Machines here.
  #13   Ban this user!
Old 02-17-2008, 02:25 PM
djh82uk is on a distinguished road
Well first test results:
I loaded it up, lowered the Z axis until the tip touched the pcb, lowered a bit more to take up some slack, then jogged in a straight line, lowered some more and jogged some more. The line depth was pretty damn uniform, there were some marks from where I stopped it and lowered it, but of course it would be moving when that occurs under normal use.
But sadly there is a problem, while trying to make a pcb, theres was too much play between the bit holder and the main body, i think i need a reamer to make sure the bore hole is near perfect, and then make the bit holder out of steel instead of aluminium, i think the bit holder needs to be thicker too, so does anyone know where I can get a 7mm chucking reamer (is that the same as a barrel lap?
At least the concept seems semi sound atm anyway, although i do have ideas to vastly improve things, I need my 4 jaw chuck to arrive and I need some reamers and a Die stock holder
DJH
  #14   Ban this user!
Old 02-20-2008, 08:10 PM
Just had my 4-jaw chuck, Tailstock Die holder and new cutters arrive so i can try and make the new and improved version
DJH
  #15   Ban this user!
Old 02-20-2008, 09:53 PM
fatal-exception's Avatar
fatal-exception is on a distinguished road
You need a zero backlash tool in the x/y directions. Make that perfect first, then worry about the z. A long reamed hole with a perfect fitting shaft is an easy way to do it. Leave the shaft untouched drill rod, ream a hole in the tool holder body to match. You can make the reamer out of the same sample of drill rod.
See the Machinists Bedside Reader for more info. (sorry, dont have a link)
  #16   Ban this user!
Old 02-21-2008, 02:15 AM
Larry83301 is on a distinguished road
Just a suggestion, slot the holder thru and use a spring pin instead of the screw and nut. That way there is nothing to fly off.
Looks like a good tool to have, when will you let us know the price? ? ?
Larry
  #17   Ban this user!
Old 02-21-2008, 10:45 AM
Thanks for the advice guys
I have considered split pins, e-clips etc, all of which I may try if i can find the right sizes. as soon as I have found one that works well, i will be able to see how long they take to make and come up with a price.
The spring tensioner is a must tho, so im going to test that this weekend.
DJH
  #18   Ban this user!
Old 02-25-2008, 08:17 AM
offroadxx is on a distinguished road
I WAS THINKING, WHY COULDN'T YOU USE SOMETHING ON THE LINE OF AN AUTOMATIC CENTER PUNCH THEORY. MAKE THE ENGRAVER TO HOLD A COLLET INSTEAD OF BEING THREADED. THEN HAVE IT ADJUSTABLE AT THE OTHER END FOR THE ENGRAVING PRESSURE THAT YOU DESIRE DEPENDING ON MATERIAL USED. JUST A THOUGHT.
  #19   Ban this user!
Old 02-25-2008, 08:52 AM
Hiya
Thats an interesting idea, I will try and get one and see what I can do with it.
with regard my version, I have a set of reamers now so I hope to spend some time making a new version
DJH
  #20   Ban this user!
Old 03-02-2008, 01:15 PM
Heya
Just an update, have been tidying up the workshop, has taken 3 days, so not got much done, ive made the new outer section, just gotta work on the inner now and give it a test, this one is someway between the one pictured, and the one I proposed.
DJH
  #21   Ban this user!
Old 04-17-2008, 06:08 AM
rayellam is on a distinguished road
DJH,
what model miller are you using to do the PCB's? any good for moderate SMT stuff? any more photo's as examples?
Ray
  #22   Ban this user!
Old 04-17-2008, 10:04 AM
Here's a drawing for a graver I made a few years ago. It's ideas are based on the one described in 'The Machinists Bedside Reader'. The long reamed hole ensures that theres zero backlash at the cutting tip.
It's been a great tool for engraving plexiglass and aluminum.
I put a detail for a simple D reamer on the drawing too. It works like a charm. I don't bother tempering the tip after hardening, just leave it full hard.
Paul
DIY spring loaded engraving tool holder cut more Engraving Machines 25 12-07-2009 12:34 PM
Spring Loaded Engraving Tool djh82uk General Metalwork Discussion 7 01-10-2008 10:35 PM
THC Floating head needs to be spring loaded? Normsthename CNC Plasma and Waterjet Machines 3 12-12-2007 07:44 AM
spring loaded rack and pinion dgalaxy CNC Plasma and Waterjet Machines 4 12-03-2006 11:49 AM
Spring Loaded Rack and Pinion request ty1295 CNC Plasma and Waterjet Machines 1 02-07-2005 11:15 PM
