Results 1 to 2 of 2
Thread: Engraving hard plastic
    Registered nosplinters's Avatar
    Jul 2006
    Hi all,
    I'm attempting to engrave on a Swiss army knife and I'm not getting very good results.
    I'm using a 60 degree cutter bit; however, I'm not getting a clean cut. I'm running the spindle at around 4K RPM. Should I be running max (10K RPM) for engraving hard plastic or do I need a different type of bit?
    I want to ask before I screw up another knife.
    What type of bit should I use to engrave onto Stainless steel as well (Diamond dragging?).
    Thanks!
    -Ed
    Sep 2007
    I've not had much luck with those 60 deg. cutters in plastic.
    Onsrud (www.onsrud.com) make a 0-Flute engraving cutter that seems to
    be the ideal thing. I've got one ordered for engraving acrylic & polycarb.
    I can't get my P/C 7310 router down to a plastic-friendly speed even running
    on a Variac outputting 30 Volts (7500 RPM). Below that, it has no torque.
    I get good results with a 2 flute upcutter but it's 1/8" diameter.
    Too big for pretty stuff but cuts very clean.
    Emory
  1. Engraving Plastic Sign Material
    By Dingo745 in forum Engraving Machines
    Last Post: 08-17-2007, 07:39 PM
  2. 2 ply engraving plastic?
    By DennisCNC in forum Engraving Machines
    Last Post: 05-07-2007, 07:37 PM
  3. 2x3 THE HARD WAY
    By MrHorsepower in forum Bending, Forging,Extrusion...
    Last Post: 02-01-2007, 12:06 PM
  4. First hard part, Help!!
    By fastolds in forum GibbsCAM
    Last Post: 06-08-2006, 03:37 PM
  5. How hard do you have to hit it??
    By zoeper in forum General Metal Working Machines
    Last Post: 05-31-2006, 12:07 AM
Visitors found this page by searching for:
Nobody landed on this page from a search engine, yet!
SEO Blog
